Hi I'm interested in building a two way or three way compression driver + woofer speaker. I've been planning to do this for some time and finally have the space and resources to do so. The build I have in mind is based on a TAD style Yuichi horn system. I don't want to go larger than an A480/A290 horn and prefer a suitable waveguide to a formal horn if possible. The less horn loading the better in my listening experiences. That said I am interested a lowering the crossover frequency of the compression driver as much as possible in the interest if achieving maximum midrange detail. Typically a larger horn enables a lower crossover frequency and increased sensitivity, which was a useful thing in the olden times when wattage was scarce.
I'm curious about peoples' experiences comparing various drivers first hand -- I'm all over the map with regards to which driver to use -- TAD 1.4"/2" would be ideal however the high price and scarcity are deterrents. The other considerations are older Altecs like the 802s or 209s if a three way which can be crossed to around 300hz. And also more contemporary brands like Faital, BMS (single and two way compression drivers), Radian, Beyma, and 18Sound. Faital is particularly interesting as they implement a "Ketone Polymer" diaphragm which as I understand it has breakup characteristics (around 9khz) closer to Beryllium than those of Aluminum or Titanium -- http://www.vueaudio.com/wp-content/uploads/2012/04/BerylliumChart_FIN.pdf.
Does anyone have experience with these drivers, new or old, or others? Which do you prefer and in what sort of implementation? Part of me would like to start with something older like an Altec driver as I find vintage pro audio gear to be excellent and see that people often tend to prefer these vintage designs to more contemporary -- high tech drivers for one reason or another. Any suggestions are much appreciated. Thanks.
