Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
It depends. You'll be able to say exactly when you've actually fixed it. A friend of mine kept two subwoofers side by side, in the single best spot)).
And somewhere in my thread, there’s a hole I used to own.
P.S. If you listen to your subs one by one, what difference do you hear\not?.
I also suffered from the sub immobility problem. My placement options were limited to diagonal corners, front and rear. The solution was a double sub mono array. Below are sweeps for respective subs and then both together (blue). Ugly, ugly!
Below is the mono array. Blue is same as above. Purple is the same but with a delay on the sub closer to the MLP. Huge notch gone! Now there's something you have some hope of EQing. Finally, orange is the final EQ'd version. The notch at ~87Hz was addressed by XO and timing integration with mains.
I used MiniDSP Studio to set it up. The result is excellent! Cheers,
