DeltaWave v2.0.8, 2023-03-28T13:08:56.6819271-07:00
Reference: D90-recording-trimmed.wav[R] 2568941 samples 48000Hz 24bits, stereo, MD5=00
Comparison: D90-recording-trimmed-plus1dB-repeat.wav[R] 2468304 samples 48000Hz 24bits, stereo, MD5=00
Settings:
Gain:True, Remove DC:True
Non-linear Gain EQ:False Non-linear Phase EQ: False
EQ FFT Size:65536, EQ Frequency Cut: 0Hz - 0Hz, EQ Threshold: -500dB
Correct Non-linearity: False
Correct Drift:True, Precision:30, Subsample Align:True
Non-Linear drift Correction:False
Upsample:False, Window:Kaiser
Spectrum Window:Kaiser, Spectrum Size:32768
Spectrogram Window:Hann, Spectrogram Size:4096, Spectrogram Steps:2048
Filter Type:FIR, window:Kaiser, taps:262144, minimum phase=False
Dither:False bits=0
Trim Silence:False
Enable Simple Waveform Measurement: False
Discarding Reference: Start=0.5s, End=5s
Discarding Comparison: Start=0.5s, End=5s
Initial peak values Reference: -11.658dB Comparison: -10.582dB
Initial RMS values Reference: -32.068dB Comparison: -32.29dB
Null Depth=26.489dB
X-Correlation offset: 163 samples
Drift computation quality, #1: Excellent (1.74μs)
Trimmed 0 samples ( 0.00ms) front, 0 samples ( 0.00ms end)
Final peak values Reference: -11.658dB Comparison: -12.022dB
Final RMS values Reference: -32.211dB Comparison: -33.73dB
Gain= 1.4401dB (1.1803x) DC=0 Phase offset=3.397088ms (163.06 samples)
Difference (rms) = -37.51dB [-56.2dBA]
Correlated Null Depth=78.97dB [35.92dBA]
Clock drift: -0.43 ppm
Files are NOT a bit-perfect match (match=0.07%) at 16 bits
Files are NOT a bit-perfect match (match=0%) at 24 bits
Files match @ 50.0006% when reduced to 6.15 bits
---- Phase difference (full bandwidth): 64.5315662089604°
0-10kHz: 58.27°
0-20kHz: 69.60°
0-24kHz: 64.53°
Timing error (rms jitter): 601.5μs
PK Metric (step=400ms, overlap=50%):
RMS=-50.4dBFS
Median=-51.9
Max=-43.4
99%: -44.03
75%: -49.57
50%: -51.95
25%: -53.92
1%: -57.4
gn=0.847217417445019, dc=0, dr=-4.29731023639261E-07, of=163.0602236678
DONE!
Signature: 3284cf201bc37a54e1cec592eaa9599e
RMS of the difference of spectra: -98.2786492403229dB
DF Metric (step=400ms, overlap=0%):
Median=-8.7dB
Max=-0.2dB Min=-20.5dB
1% > -19.8dB
10% > -14.56dB
25% > -11.03dB
50% > -8.71dB
75% > -6.58dB
90% > -3.93dB
99% > -0.15dB
Linearity 4.5bits @ 0.5dB error
