Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
If I use an RCA splitter from my DAC to send two sets of L and R to two pre-amps, going to four amps in a bi-amp setup, will this sound better than using splitters on the output of a single pre-amp?
The splitter is better, and with 2 preamps you STILL need to split to both pairs of preamp inputs. With multiple sources you'd need multiple splitters.
With 2 preamps any adjustments will have to be done to both. But it would allow you to adjust the levels separately if the power amps don't have volume-gain controls.
...Usually with bi-amping you have an active line-level crossover instead of a splitter but that means you can't have speaker-level crossovers built-into the speakers.
