You could go with a pair of monoblocks.
Amir just reviewed the Buckeye ET9040BA With XLR, you could put the MB a lot closer to the speakers and run a lot shorter speaker cables with longer XLRs. You just need an electrical supply for the pair.
You will have a very nice pair of amps for any future changes if you ever decide to go to a stereo preamp.
I was using a McIntosh MX121 for quite a few years in a Home theater setup. I like it for the simple reason that all Macs (I own) have tone control and the fact that I've used McIntosh gear for well over 45 years.
I suspect the 1ET9040BA is very transparent. One of the reasons I like NCore products they don't boil my ears. I guess your ears are much like mine. I'm sensitive to many AB SS amps and hot or tipped-up tweeters with no L-Pad, EQ, or tone controls. Fatigue sets in pretty quickly. I don't get that from the NCore NC500oem MB I use or the valve amps I use for the monitor section on my preferred speakers. I don't care what anyone says, if I get to squrming while listening to my favorite genre of music, it's usually the same thing. Great SS power amps, like Krell, SST, Parasound, and I'm sure there are a few hundred more, they wear me out in under an hour, especially if the volume is UP.
I got to listen to a pair of Atmasphere class D GaN MB for 3 months. Wonderful amps. If they weren't so expensive I would have picked up a pair, but I'm up to my neck in equipment already. I push them pretty hard, and they did run out of gas on a pair of VMPS RMX Elixirs, which I expected, but I assure you they will still BLAST pretty good. Less distortion than most valve amps, too. Very controlled distortion no matter the passage, like many older valve amps, unless they are massive VTL, ARs or Macs. I'm sure there are a few dozen I haven't heard. If I wanted solid-state sound, I'd use a solid-state amp. Pass and First Watt are easier on my ears, too.
To be honest, valve amps are suited more to my taste, in (almost) every single way, HEAT being one problem in the warmer season. They do keep the house perfectly warm in the winter, where the wife listens to music, and she likes the signature sound of Cary. V12Rs definitely have a sound using the EL34s Rubys they came with or GL KT66 for a little more roll-off above 15KHz.
Whatever you choose, the Buckeye is a pretty solid choice money-wise. I have to admit, it's not the most impressive case I've ever seen, personally coming from a Nord, McIntosh, and Cary (preference of looks) background.
In any case, enjoy.
Regards
