Tweeters for my speakers
Ok thank you both, i am going to order those tweeters from ebay, and look for a capacitor in that range locally. Also inspect the cables. so if all goes ok it will take around 2 - 3 weeks will be back on the forum by them thank you all for the help.
Only decent output from 5 kHz… I’m not sure if that will work given the 8” woofers.. but if there is no crossover on those either, it might work…? Lobing will be horrible.. but that can’t be helped now.
sorry i deleted that spreadsheet it turns out it is a different speaker its was for this one thanks: https://www.parts-express.com/GRS-1TM-4-1-Mylar-Tweeter-with-1-2-Voice-Coil-4-Ohm-292-438?quantity=1
so easy to get misleading info and then be confused.
i'm still set to get this one thx:
