tweeter with repeated dents
musica
I found a used tweeter, with those marks as you see in the photo, they can affect the quality of the sound, it costs 30 euros less than a new one.
That's a few minor creases (I presume the dome was dented, and someone has repaired it).
Would you hear any difference? I very much doubt it.
Would there be a measurable difference? Well, you might see a few tiny peaks or troughs in the frequency response at high frequencies.
Personally I don't think it's anything to worry about.
It's a B&W tweeter isn't it! They are always being pushed in by children!!!
so, I buy it, because mine burned out
I bought a new one for 30 euros more?
Behind what you see,around the back edges is the voice coil and it's attached to it.
This (the voice coil) has to be a perfect circle as it was when new and it's so fragile you would trust yourself to hold it with two fingers.
Now,imagine what happens in the back when someone pushes it in the middle.Will it stay perfectly round?
Nope.
Nope.
the tweeter is already in its case, so no one will attach it to the speaker cabinet without using any effort on the B&W tweeter
Nope.
It's rare for the voice coil to be deformed in circumstances like this. The coil is wound on quite a strong former, and being circular already has some inherent strength.
I've repaired many tweeters like this, both metal and fabric dome types. I've never seen damage to the voice coil, except where the tweeter dome has been completely ripped out of the chassis. And then repair is impossible anyway.
De
It depends on the tweeter I guess.
A soft dome is maybe way more fragile but it could get away with a soft push as small forces will be applied to the whole body.
An alu like that one the other hand is impossible to get away from a push as it reacts a whole body.
I wouldn't buy it and if I would,I would immediately measure it to see if the known peak low in it's range has occurred along with the rapid fall from 10kHz and above,as most pushed tweeters behave.
For the OP,look how is made and how thin it could be:
Resurrecting the thread for some visuals.
These are large towers with alu tweeters which one of them had the sad fate to meet a small boy.
Friend who owns them is already waiting the dealer to change it on the spot but it was a chance to measure:
FR, I think it's evident which one had meet it's maker.
and the distortion.
One could not even see the damage as it was not stayed pushed, it just ended up with a small dent.
Now you know if you ever see such response.
Indeed - I could see that greatly impacting the dome's ability to remain pistonic / avoid breakup.
and the distortion.
I assume these measurements were carried out in controlled conditions?
Even room placement, objects in the room, and differences between speakers could account for the response differences observed here.
Tweeters in particular are not always well matched even from new.
These were absolutely matched, we have measured them in that exact spot in his room many times and they were in very good agreement.
Aside from FR though, distortion chart is a great tell by its own.
And of course you could hear it during the sweep, it was like the sound was dulling, widening and bending when reaching the tweeter range.
If you search diyaudio you'll find similar that have been pushed in the same fashion,even silk ones (more fragile as pushing deforms the VC) .
We'll measure again the new one next week when I'll visit, let's see.
