Tweeter Replacement
JRAP
I have a pair of Cambridge Soundworks Tower II speakers with a dead tweeter. Asking for options advice. Thanks
Welcome to ASR. Can you contact the manufacturer's customer service and order a spare part, either directly or through his distributor?
Else buying an aftermarket tweeter will require some reengineering, both fitting the part and/or adjusting the crossover level/frequency.
Welcome to ASR!
Pics of dead tweeter would help see if it is a known supplier. Also, if the flange diameter is about 104 mm, you have more choices. If cannot get exact match, might find a close one.:)
Is one tweeter is working?..
https://www.hifi-classic.net/review/cambridge-soundworks-tower-ii-101.html - a regular modern tweeter with a suitable flange, ~90 dB, 4 ohm nominal might work just fine without any changes to the crossover (both would need to be replaced)
