Turntable Recommendations
Buckeye Amps
Hey all,
My brother wants a new turntable and was hoping to get some recommendations. He isn't a huge "audiophile" but still wants something very nice to play our dads extensive record collection and also, if possible, digitize playback onto his computer for certain records. Essentially he wants the best of both worlds for analog and digital playback.
He has been looking at the Audio-Technica LP-120XUSB but wanted to check in here first if there were any other recommendations. Budget is up to $1k.
Thanks!
I have this exact model and can recommend it. Direct drive and a decent pickup.
The previously "dubious" antiskating is fixed. Digitizing is also very easy, no extra RIAA correction necessary.
A version with Bluetooth also exists.
I was in the "first wave" of stereo LPs - I sold up in the 90s and would not go back...
But I think the Audio-Technica LP-120XUSB is a great recommendation.
People can argue about mechanical nuances that most don't care about, but in the end, if you make it easy to digitize some prized or rare LPs before they wear through and start playing on both sides at once :) that has to be good. A minimum of (any) PC and (free) Audacity is good enough. Even if you play the LPs "live", bluetooth is good enough. No point worrying about over-priced phono pre-amps or needing inputs on a modern amp....
Yes, I agree. In any case, it's technically impossible to improve the sound of a vinyl record in any way by spending more money. The medium is simply too low quality for that.
I myself bought two used turntables for about $15 each to digitize some rare recordings, and that's more than enough.
For the price the Audio-Technica LP-120XUSB is probably hard to beat. I would add an ML stylus for the AT (or personally rather go for the AT-VM745xML cartridge). If there is a large older collection to be had I would also suggest a Humminguru US cleaner.
A Waxwing sure does improve the sound of questionable vinyl, even well recorded albums.
The Technics SL, hands down.
It’s a tank—sounds absolutely fantastic, easy to set up, rugged, and built to last forever. You can find them used at that price point; you can resell it whenever you want, and if you prefer, you can upgrade it.
I think it’s one of the best Hi-Fi products of all time—truly amazing.
While I prefer my SL1200mk2, it would be kinda pricey these days (and can sell mine for more than I paid for it 40 years ago). I'd be happy with the AT mentioned.
My estate sale Technics 1200 came with an AT Series VIII cartridge, which seems to be a rare bird. I use it to digitize old records. The stylus is an exotic shape that seems to ride outside the worn part of the groove.
I picked up Audio Technica lp8x. Does everything I need it to do. Sounds great as well.
He can look at Rega's as well. The better TT and Cartridge the better the Lp's will sound. Does your friend have an amp/pre-amp with a phono section?
The convenience of a decent cartridge with a decent direct drive tt and inbuilt adc/usb output for digitizing vinyl all for one nice price is really hard to beat.
I'll chime in and say an older Technics direct drive TT. As mentioned, built like a tank - mine's been spinning for almost 40 years with no problems beyond changing carts.
Given the size of collection, perhaps it would be worthwhile to budget for a Parks Audio Waxwing phono preamp in the signal chain.
Hey all,
Thanks!
For digitizing I'd recommend getting Audacity (free) and VinylStudio to remove noise, get rid of clicks, split tracks and convert to export to the filetype and location of your choice. MP3Tag is good for fine tuning track numbering and file naming.
I have this and have not used for awhile but when I did I witnessed a few resurrections. Many good recipes for home brew cleaner on the net with the key ingredient a few drops of Kodak Photo Flo 200. They say 8 records per batch but five worked best. 2 new baths per 1st batch and the second batch can can use fluid from the second bath of last bath as first and keep going for a marathon cleaning session.
