Short answer? no
You'll have much better results with a planar 3 + nd7 cartridge (fine line stylus) than a planar 6 + nd5 cartridge (elliptical stylus)
Choose wisely based on data and not on dealer talk.
NOOOOO!!!!!
Have you ever directly compared a 3 with a 6?
Firstly, the 3 runs fast as all Regas without the external Neo supply seem to do (I checked every one I sold back in the day and have spot-checked others in the years since). The Neo offers fine tuning of running speed (can't remember if the original external generated 24V/50Hz supply offered this) and it's worth it for that alone in my opinion!
Second, the added platter mass of the Planar 6 does seem to help, whether it's in reducing wow figures, or the extra mass aiding the cartridge in reproducing bass and any semblance of 3-D off the vinyl better. A Planar 3 sounds pretty 'mechanical' and 'one note' in the bass even compared to 'digital' and it takes a lot (their wall bracket, maybe a mat change - shock-horror) to minimise that. It's NOT the tonearm either as I've used RB arms, especially the 300 series, on other decks to great effect...
Lastly, their new home-made pickups have yet to be properly tested, so all we seem to have right now is subjective comments (the old Elys 2 and Exact 2 were pretty low bar, even when first launched forty years or so ago as they exhibit quite strong response anomalies). £200 is a lot to spend on a bonded elliptical when one can get a VM95 SHIBATA for less money, a bonded elliptical VM520 for two thirds the price or less, or a 'micro line' VM540 which may be possible under £200 here now while stocks last (no idea if AT will continue with it now thew VMx740 is the price the 540 used to be).
The SL1500C with 2M Bronze stylus upgrade added is making such an incredible case here I have to say - sorry Rega, but it's true, even in the home UK market, as prices have gone up a bit too regularly recently...
As for VTA on an RB arm, remember the tube is lightly tapered, so should always appear to be slightly tail-down. Also, many diamond tip rake angles seem(ed) to be set a little too fiercely (often around 28 degrees rather than the more EU usual 20) and distortion could sometimes be slightly tamed with the arm set slightly low at the pivot end. I was told decades back the 1/10g difference in tracking downforce could be equivalent to around 2mm pivot height difference, this with a medium compliance stylus assembly. The better pickups today from Ortofon and AT, have enough tracking margins for this to be experimented on perhaps. I never got on with the spacers myself, despite having a collection in my toolbox (and a newly acquired mint RB 300 to use them with if necessary once I get a deck sorted for it)
I'd also suggest seeing if Rega still have the extra-heavy tungsten counterweight available, If a (what should be a great) VMx740 was used, I think getting the counterweight as near to the pivot as possible (minimising inertia) would be as beneficial today as it was in the days of the inferior Linn K9 (AT93/95 body with metal mount and 'vital' true-elliptical stylus).
