PHD
- Joined
- Mar 15, 2023
- Messages
- 274
- Likes
- 394
Hi
Following this post regarding my unlucky purchase of the Denon X4800H:
The first unit had a random strange sound upon turning on and was sent to the service lab. After they communicated this with Denon they decided to replace the unit. The unit I got was from the same manufacturing date and unfortunately had the very same issue which can be heard here (first turn on with normal click noise followed by second with abnormal noise):
Meanwhile, the first unit was further tested at the local service lab and they told me that they did manage to identify the source of the noise, which was the main power transformer.
The root cause is vibrations from surging inrush currents which only occur when I turn the unit on while the AC waveforms are near their peak values. They said that while not all units are affected by this phenomenon, it is considered normal and harmless.
While the explanation does make sense, I can't understand how is this normal? Such an advanced AVR would have adequate inrush current limitations to avoid such a problem. Since only a subset if units are affected, I think I have the right to demand a replacement with an unaffected unit.
What do you think? Does this explanation make any sense? Would you keep the or return it?
@Doodski
Thanks
Denon X4800H random fluttering relay sound when turning on
Hi After only 2 weeks of usage, now, when I turn the X4800H on, the main PSU relay makes a loose spring or flutter noise randomly. In this video the spring sound only happens at the 2nd turn-on attempt...
www.audiosciencereview.com
@Doodski
Thanks
