wonderfulaudio
- Joined
- Sep 5, 2025
- Messages
- 20
- Likes
- 5
Hi,
Magazines like Elektor and Siliconchip have published projects long time back that emulate the Tube/Valve sound using solid state. Tubes/Valves dont have a linear curve and when run without feedback, they produce even order harmonics that are perceived as warmth. While I believe adding or subtracting anything to audio is not truly neutral but I have heard one such tube preamp and it did have a likeable sound for lack of a better word. This is a fun project where I can bypass the circuit with a switch if needed.
I have seen 2 different implementation of the method:
1) Using JFET in non linear region, I managed to isolate this JFET part
2) Using op-amp and a soft limiter, I dont have access to this though I am sure it was published in Elektor in 90s
Below is the JFET schematic, I would like to modify and experiment with it.
Q1 is configured as voltage follower and designed to work outside its linear region and is soft-clipping.
My problem is its biased such that its transfer curve is not symmetrical for the full swing of the input signal from the opamp.
How to make it symmetrical? Probably by adding a complementary FET to Q1 but how? Can somebody please help and explain me how to modify?
And what does VR2 do, it certainly does not drive Q1 symmetrically even though the name suggests in the schematic?
Also, there are op-amp based clippers used in guitar fuzz boxes, they dont sound same as tubes/valves because they have hard clipping.
I would appreciate if we can make progress with above JFET method as well as better op-amp based circuit than fuzz boxes, diodes on feedback loop of op-amp dont work.
Thanks and Warm Regards,
WonderfulAudio
WonderfulAudio
