Tube Radio
tengiz
Seattle
For some reason I've been getting nostalgic about old console tube radios - the kind with a real mechanical tuning dial, cat-eye indicator, warm light behind the scale, big speakers, and beautiful woodwork.
I remember them sounding almost magical back in the 1970s, and even into the 1980s, which is probably the last time I actually had a chance to listen to one. Now, roughly half a century later, I suddenly have an itch to own one.
I could probably repair or rebuild one myself, but at this point I just don't have the energy to start chasing schematics, old parts, capacitors, and everything else that comes with it. I'd much rather find one that's already been properly restored and is ready to use.
Any suggestions on where to look, what to look for, and what to avoid?
Thank you!
Thank you!
Are you familiar with Carlson’s Lab on YouTube?
You might find some inspiration there.:)
In this video, he installs a Bluetooth receiver into an old radio. Note that he keeps the original tube radio/amplifier intact so he can use its analog AM section, but can also switch over to Bluetooth and feed that signal into the old tube amplifier:
If I were doing something similar, I would remove the old tube radio completely and install a new amp with a built-in Bluetooth receiver. That’s because I lack the technical expertise to work on vintage tube radios. I would simply keep the chassis for its cool retro look. On top of the new Bluetooth amp, I would also install new full-range speaker drivers.:)
Born in the 50's, I feel the same way about them as you do, though I am on the tail end of that group as most of the tube radio listening and restoration hobbyists have died off. That's good for prices which are much lower than they were 10 years ago.**
I restored electronically and aesthetically tube radios for many years, although as I lived in an apartment and sold them on eBay, I restored only table models. Attached is the before/after of a unique 1937 Sears Silvertone I restored that mimicked a console radio. These days they are of course collected for aesthetic reasons rather than technical. In the U.S. I would say the Zeniths were the most electronically sophisticated in the later years, before the 1930s others like Atwater Kent or Stromberg Carlson would have been perhaps the zenith.
As for advice, most major metropolitan areas still have antique tube radio collectors clubs that meet a few times a year. Go to a gathering an you will find fanatics rivaling anyone on this forum, but with added wood and plastic refinishing skills. Most will love to discuss, share knowledge, and sell their radios to someone who appreciates them.
For consoles, Craigs List and other local swap forms are a good place to look as shipping costs for consoles are so high most eBay items will be out of range. Buying from individuals will likely cost a lot less than from antique stores, with the benefit of getting to talk to the restorer. There are a lot of good deals buying from estate sales though the restorer may no longer be talking. The best advice is to listen to and inspect whatever you are considering. If the radio can pick up multiple stations without hum/buzz and if it looks great, then it was well restored. It will probably need a tune up every few years regardless, but most people do not play them constantly. Distance buying is fine for table radios but requires greater knowledge of the seller's history, as "restored" means different things to different people.
Compared to modern electronics, they are also much easier to learn and repair, except for the much higher likelihood of electrocution from their high voltage chassis.
An alternative to installing a Bluetooth receiver into a radio that leaves the radio intact is to buy a small AM or FM transmitter, some have Bluetooth receivers in them. This allows the tuning, cat-eyes and the like to do their work and keeps the innards pristine. The audio will be similar in either case unless you replace the radio's amp and speakers as well.
**I made a similar comment about stamp collection prices in a forum a while back and received the best response in forum history...."Thus proving the adage, philately will get you nowhere."
That’s a good idea. :)
For instance, I visit a radio museum in Gothenburg every couple of years. The more active members swap parts, meet up, and discuss radios, repairs, and so on—you could think of them as gatherings for retired folks. I’m not that old myself, but I’ve sat there (in the museum café) chatting with the old-timers.:)
I feel like similar museums and clubs ought to exist in every country. After all, radio used to be such a huge thing—and it still is, even if we call it podcasts or internet radio these days.:)
That's a very good idea. A similar museum in Minneapolis was by chance, a block from where I worked at Audio King/Ultimate Electronics in the 2000s. I taught new electronics consultants and took them on field trips to the museum to appreciate their profession's history. Even then it was staffed by previous generation ASR types.
This would have been a great input to the "Does anyone else like FM Radio" thread.
It would, I guess, but I mostly listened to AM :). I mean, since FM is (and was) mostly local, to listen to stations beyond the local area one would generally use AM. And for the longest reach - SW.
Oh no! He talks about ham radios as well, and that would be a very deep rabbit hole for me. I used to be a very active CW operator ages ago - I even won some prestigious worldwide contests. I've deliberately stayed away from the hobby for decades because it's so addictive and time-consuming.
If I started working on old radios, I would certainly enjoy working with tubes again, but I want to avoid getting drawn into it. I already have other things to do that are quite time-consuming :)
I read and sometimes contribute to the vintage-radio.net forum. It's UK based, and heavily moderated to stop threads going off-topic, but it has a wealth of information on all vintage technology. Service manuals are available for a vast range of equipment.
S
Cool!
Thank you! Unfortunately, the local vintage shop I visited doesn't have any tube radios, and most of the gear they do have isn't nearly old enough. Craigslist around here doesn't seem to have anything that would tempt me either :(
So I guess I need to accept that this is going to require some patience and start hunting...
I've had enough electric shocks over the years that I'm almost used to them :). The worst was when I was playing with a 200 W RF tube stage running at about 1.2 kV DC. Touching the anode with the stripped end of an insulated wire made enough RF noise for the radio to pick it up, which I thought was cool. I assumed the insulation would hold and just made sure not to touch the chassis. Then my palm did. Luckily, it was the same hand holding the wire, but I still badly burned my fingertips and palm - and have the scar to prove it nearly half a century later :)
OK, @tengiz
Here's the thing.
At one level, "old tube radios" are very simple, but, since they have to work with high frequencies (RF) and work some analog magic using oscillators to pick up radio frequency signals, generate local signal of an "intermediate" frequency (s), then combine (mix) frequencies with a high degree of precision to generate easy-to-amplify and, subsequently, detect, there's a lot of fairly detail-oriented activity in even a simple AM table radio.
I don't want to dissuade you (far from it!), but if you have very little, or no, experience with analog electronics -- start with an audio frequency amplifier. They're far simpler and less picky in terms of tuning (there's virtually none -- AF amplifiers are generally not supposed to oscillate ;)), lead dress, layout, and the precise value(s) of parts in the circuit.
Get your toes wet (figuratively! We're talking lethal voltages here! ;)) with rehabbing (or scratch building) a simple audio frequency amplifier then try a radio.
If and when you tackle a radio:
1) by all means and if at all possible, start with one that has a transformer operated power supply. Safety first! Some very old AC-DC transformerless "killer" radio circuits dealt with "excess" line voltage via a resistance-loaded AC power cord. These radios are works of Satan :eek: and earned the nickname curtain burners for a reason. Even "normal" transformerless circuits are potentially very dangerous and at the least should be isolated from the AC mains with a 1:1 "isolation transformer" for servicing, and, ideally, for use.
2) Start with a broadcast frequency (medium wave) AM radio. Way simpler, work at lower frequencies (where layout, etc. are less critical), far more tolerant of mis-alignment, and far easier to align. FM is far more complex to deal with and difficult; MPX stereo FM even more so.
3) If at all possible, start with a "known working" radio. E.g., a radio that works fine but has a loud buzz; replacing the filter capacitor(s) will likely put it ready to rock 'n' roll with little or no further rehabilitation (although decades-old coupling capacitors are always suspect).
4) Resist the temptation to shotgun all original parts (tubes, capacitors, even resistors)! Tuned circuits are tuned to the components that are installed in them. While it's absolutely true that drift and degradation of the decades-old components in an old radio may have caused drift and even functional failure of the tuned circuits (e.g., a local oscillator that doesn't), replacing all of the parts in a tuned circuit is a pretty good way to make it even more likely that the tuned circuit will not work. :( Now, of course, those tuned circuits contain tuneable elements (e.g., IF transformers) but this isn't quite a trivial exercise, even for AM radio, and the tuning slugs of 70 or 80 year old IF "cans" can be an exercise in exasperation when they break.
The classic "All American Five" radio design was nigh-on ubiquitous and not a bad place to start EXCEPT for their series-string tube heater, transformerless, killer power supply. You can buy or make an isolation transformer. Two identical isolating power transformers with adequate power rating, connected secondary to secondary, is an easy and relatively inexpensive way to get an isolation transformer... or you can buy a purpose-made AC isolation transformer.
There are several forums and groups dedicated to old radio restoration.
Also, look for local resources. Here in New England we have ham radio groups and also an antique radio group:
Real, local people who can serve as mentors are invaluable.
Hope this is helpful, or at least interesting.
What mhardy said. If you do want to learn about RF electronics, you'll want books like the Radiotron Designer's Handbook and the ARRL Handbook. Others might know more good reads.
You should definitely own a copy of the RCA Tube Manual, in any event.
There was/is at least one person in the Denver metro area selling consoles, but the example I saw had been "modernized" with all-new electronics. Looked great, but I don't know that the shop displaying it sold a single unit.
Years ago, I performed a full restoration of a 1959 Grundig Majestic 4095. I recall the sound being pleasantly full and room-filling, and imagine it might have been the focal point of a family's entertainment, at least until they got their first television set. It originally used an EM34 magic eye, but these are mostly unobtanium these days. But it's easy to rewire the tube socket to accept Soviet 6E5S tubes, which are still plentiful. Central controls are a for a 5-band graphic equalizer with red cord providing a visual representation of the settings. Sold this unit more than a decade ago as part of a general tidying-up of my place.
I recall restoration being kind of labor-intensive, and I replaced every single rolled paper and electrolytic capacitor. If it had a selenium rectifier, that would've gotten replaced with modern silicon + dropping resistor, reducing the B+ voltage to spec.
But I still got this thing: 1943 Bang & Olufsen Master 43K. It's aesthetic reflects wartime use of non-strategic materials, hence, reduced use of Bakelite, which was a British product embargoed from Nazi-occupied Denmark. Can be operated from a wide variety of voltages, including 100 volts DC! As a result, the power switch has a strong snap action. Haven't done much with it, partly because I feel like I should preserve the appearance of the old resistors and other components, but TBH I haven't decided quite how to do it, or whether I'm being needlessly fussy.
Dial lamp is unlike anything I've seen before: It's a slender tube running the full length of the tuning dial. Somehow it survived the trip from Denmark intact. If I ever get this set operating again, I'll probably fabricate a warm-white LED strip with diffuser to simulate the appearance of the original.
Trivia: IIRC the original B&O logo was the creation of Henning Dahl Mikkelsen, better known for the Ferd'nand comic strip.
Toaster-sized radios seem to be most popular with collectors, but the examples I've heard to date have been nothing special sonically.
Some large tabletop sets from Telefunken (I think) were equipped with electrostatic tweeters. If still functional, I'd be curious to hear those.
Thank you.
I do have experience with both analog and RF. And with tubes. I'm old enough to have overlapped with the time when the output stages of ham transmitters with any serious power were exclusively tubes. I mean, for mere mortals :). And generally, I cut my teeth on tubes because they were so much more readily available, especially in the old-school surplus military equipment we could get our hands on.
My problem is that I just don't want to do it myself.
I'm from Denver. I met a member of the Colorado Radio Collector's Antique Radio Club last spring to donate the rest of my collection and parts. I see on the linked page their annual auction was last weekend. The auction video shows the demographic of remaining collectors, as well as the drastic price deflation. Its a good time to find deals.
The most expensive radio, $1000+ was a rudimentary tabletop with a prized Catalin plastic cabinet. Most radios went for less than $100 with the saddest, for me, being the working Zenith Trans-Oceanic suitcase sized "portable" H500 at the very end which sold at the minimum $20. As the auctioneer states, 10 years ago it would have sold for $250+. My dad had a radio in his den very much like that one which could indeed pick up broadcasts around the world.
I saw no consoles, but I am sure many of the collectors would have had them or knew where they were available locally at far less than antique store prices. I facebook marketplaced my Victrola console phonograph, earlier this year, in great shape with dozens of 78s for $200. That's less than it sold for new in 1915 NOT accounting for inflation.
Your photos are great! I collected or worked on U.S. radios which were usually less sophisticated but stylistically more diverse. I did have one Pre-War Blaupunkt (1937) that your B&O reminds me of. I really enjoyed that radio, quite handsome, see below. I'd happily post a lot more tube porn here though I expect the audience would be enthusiastic but tiny.
That Blaupunkt looks fantastic, really shows off the wood. Don't see wood displayed like that anymore, except in high-end furniture.
I'd be okay with more photos, but I don't have many more of my own to share: Repeated moves from one compact dwelling to another have seen me shed a lot of bulky, heavy, or fragile items over the years, and a couple of those items were a pair of Zenith Trans Oceanic projects which never got started.
What I used to do is browse enthusiast fora with good international coverage in search of designs which really caught my eye. And once I had a sense of what brands and models had the visual appeal I sought, I'd want to inquire whether they were known for good sonics, and what tubes were needed. Were said tubes still readily available, and if not, were there good substitutes. I prefer an international scope because I don't want to be limited to products most commonly sold my region.
