I own a tube preamp that I bought used in late 1990's.
Have replaced four E88cc (6922) tubes about every 8-years, never replaced the four PC900's in the med/low phono section (that I can recall).
The replacement tubes have been two in the main line section, and two in the phono hi-gain section.
I have never experienced noise/grain only excessive heat, loss of both channels or weak channels in either R&L that migrate randomly between R&L prior to replacement.
These failings happen in both CD and LP playback, not just one or the other. In other words, in the line stage.
I have always used the medium phono gain at 47k for MM cartridge. Never used a MC and do not plan to.
Question: from the diagram in lower left, the two tubes labeled "phono hi-gain", do you think these are in any way active when using a MM?
Reasoning: if these tubes have never been used then I perhaps can rotate them into the line-stage section, right?
EDIT: the price of these small preamp tubes is kind of crazy, and I do not have a tube tester. Just looking to be frugal but safe.
