Hi,
I hope this thread is posted into the right category. If not, please accept my apologies.
I'm looking for a replacement of my tube preamp FX Audio Tube-03 which has served me well over years but has some flaws (only one output, no remote, too light so the cables make it move).
I've thought you guys would have good advices for not-so-expensive tube preamps which have good measurements. I really would like to have two outputs, by the way, because I'm feeding several amplifiers and systems with a single preamp. I'm quite fond to the "tube bloom" or "syrupy sound" of tubes, which is probably distortion or third harmonics so it's certainly a flaw from some point of view, but I like this. I don't need a headphone output, I have headphone amps.
By the way, I have another bonus question which is not related to tube preamps: I use a toslink (optical) cable to connect my source (a PC) to my dac. Would I get some audible difference if I bought an interface to connect my PC to the dac using usb or aes/ebu or spdif or, well, any other more modern kind of digital connexion? I know toslink is quite old and limited but if you don't look at the numbers, is there an audible difference with the others? I can't make the comparison by myself and I think if I can have a reliable answer somewhere, it's here.
Thanks in advance for the help and comments.
