Any suggestions for decent tube headphone amp or just stick with solid state
looking at Ollo Audio and Sennheiser 6xx
32 OHMS ON THE OLLO
I built the Pete Millett Butte headphone amp for a friend, upgraded it a bit (larger aluminum case, Alps blue volume pot, internal power supply). I also added a Glass Audio tilt control to a second switchable input and set that up for a +/- 2dB swing.
He listens with planar headphones and it sounds great. He uses the tilt control 99% of the time for a downward tilt towards the treble.
I set it up with a 5 ohm output impedance to add a little uncertainty or "tubeyness" to the frequency response (on purpose).
Didn't our own Solderdude design a solid state headphone amplifier which replicated the sort of sonic signature of a tube amp? It was on this site not so long ago but I have forgotten the name of the product, sorry. That offered the sound tube buyers seek with the painless ownership of solid state and it wasn't expensive. Might be just the ticket for you.
Isn't it a solid state design?
How is 5 ohms make it sound tubey?
It's solid state, yes. A higher output impedance causes freq response to be slightly modified by the load just like in a tube design. But there's less distortion.
You're right, but he has other low z phones that it does impact.Planar headphones are insensitive to output resistance, the FR doesn't change not even 0.01dB because the impedance of planars are completely flat.
