mirekti
- Joined
- Apr 28, 2016
- Messages
- 33
- Likes
- 10
Hi all. I am ready to introduce some distortion to my living room and add a valve amp.
My spouse uses the system on a daily basis to listen to radio and what not. It would be somewhat bad she did that burning my valves so I had an idea of keeping the current amp, add the valve amp and introduce an amp switcher.
Not sure if this is valid for any amp, but I was warned the transformers in valve amps will blow up in case there’s no speakers connected to it. The problem is I only have a single pair of speakers and devices like Fosi don’t provide dummy load if powered off (that’s hazard if left around with my spouse)
Is there any passive device one would recommend I could use in this setup?
Something small and simple to do following:
Switch in a position A:
AMP1 –> Speakers
AMP2 -> Dummy load
Switch in a position B:
AMP1 –> Dummy load
AMP2 -> Speakers
AMP1 –> Speakers
AMP2 -> Dummy load
AMP1 –> Dummy load
AMP2 -> Speakers
