Update: I don't have any measurement equipment on hand, but the driver volume of the HE400se seems to be off by about 3 dB at 1 KHz according to my ears. I amended my EQ profile and reduced the preamp gain of the left channel by 3 dB. Now the stereo imaging is excellent and music sounds like it should. I may even enjoy the EQ'd sound more than the Edition XS (also with EQ). It has a smoother treble response so there's fewer peaks to tone down. I sure as heck enjoy the comfort more.
Still not sure about the weight for long-term use, but the HE400se is back in the running now. It's really good. So good it's kind of screwing with my plan to reduce this collection to only two open-back headphones. I paid just 50 € incl. shipping for my pair so there isn't a lot of money tied up in it. Gotta give it some time, I guess. Maybe it won't see any use in practice.
I've spent a decent amount time with the SR60 and SR80 and filed them under "not for me", but it may be because I only heard their stock sound. I'm not opposed to on-ear designs and it might be fun to experiment with the myriad mods, especially the ones meant to make them more comfortable. But I don't think their stock bass response is that promising for the immersive Harman bass I'm after. AutoEQ profiles boost the sub bass by around 12 dB to reach Harman levels. Maybe they can take that, but I'm doubtful.
I think a friend of mine has an SR60e. I'll at least give it a try. Thanks!
Also, please, don't discount Audio-Technica. Maybe you've only heard the more ubiquitous closed-backs. The R series is amazing.
I don't have any heavy hitter amplification. Most of my desk listening time is spent running off the MOTU M2's headphone out. It's a bit weedy in terms of power, but it seems powerful enough for the headphones I've had so far. Even with ample negative preamp gain I usually end up at around 1 o'clock for my less sensitive phones. Sometimes I also use the FiiO KA11 dongle as a DAC/amp with my PC. That thing is
considerably more powerful and has measured exceptionally well in Amir's review on this site. I don't notice any difference that couldn't be attributed to suboptimal level matching. Not with the planars, not with the HD600, not with the K702. Both devices deliver enough clean gain for my needs and their differing noise levels, filter roll-offs etc. are beyond my hearing ability. Could it be
different output impedances you're hearing? What's your unamplified source?
I felt the K702 was okay, but the treble is a little peaky for me. As stated above, I had to do some surgical cuts at around 5,6 KHz, just below 8 KHz and around 12 KHz to get the treble under control and it still sounds a little grainy to me sometimes. Getting the bass and mids to a good place was really easy, though. Nicely spacious presentation, too. Easy to enjoy if the treble aligns with your hearing and preferences.
Added to the list, with the caveat that it might also be too similar to the HD600, like the HD550 mentioned above. I never thought of the 500 series as "fun", though they present as much more spacious than the 600 series. I'll get my hands on either and just try to make them fun, I guess. They are very comfortable for me!
I don't know if an estat would fit the role as well as a dynamic driver or planar headphone. This is about sitting at my desk, having both headphones on hand and switching one for the other when I want to play games or watch a movie for a while. Not exactly the best use case for an estat if I don't want to keep it powered on all the time.
The Shure graphs very well, though. Nicely extended bass response. Added to the list, thanks!
