Do you have a link for that eq post please? (or do you mean you would like him to do one?)
It's in the video, if you want the IE2019 tuning then you need this.
I have the Kiwi Ears Cadenza. It did not work for me at all. Those 8K and 12K peaks that one usually attributes to measurement artifacts, they are real with Cadenza. I am yet to hear Red of course, but I doubt it will be anything like the Kiwis. And to me this gives the impression that random measurement results with random rigs and no references do us no favours, might be quite the opposite even.I never got the Kiwi Ears Cadenza, but it is only $35 and damn close to the Red:
Can't help but shake that the Blue is slightly harsh now compared to the RED tuning.Good for Crinacle to post an EQ to mimic the sound of Red on the Zero. The Red sound is tempting to me but I found myself consistently preferring the sound of the Zero. It's just a bit more exciting. Maybe my 50+ old ears like the little bit of treble boost.
From experience. You are not trying to analyze an arbitrary system here. You have a specific situation where some characteristics are known such as reflections inside the cup. This is similar to modal response of the room where nulls appear. These are non-minimum phase regions where in theory you don't want to equalize. In practice, it may be worth trying since you want to smooth out the modal response if you can (assuming you have amplification power/dynamics in the speakers). Due to much smaller air volume inside headphone cups, these reflections/non-minimum phase region fall in high frequencies. And are easily seen by large peaks in Group Delay:But how can you determine that the measured group delay shows non minimum phase behavior without comparing it to the minimum phase group delay?
While diagnostic value of GD is quite low, you do see things like the above example I post (internal reflections causing the messiness in the 1 to 5 kHz). Looking at the frequency response is not revealing:This example demonstrates that there is no virtually no behavior that is inexplicable by magnitude response, and the only way to know this for sure is by comparing the measured group delay to the minimum phase group delay to get the excess group delay (or by looking at the excess phase response).
I haven't been following the RED Project hype. If Crinacle has been trying out his RED tuning at audio shows, and then making adjustments, it does sound as if the RED concept started soon after release of the 'Blue'. Maybe simultaneously? I find it impossible to get my head around the speed and direction of budget IEM marketing.
I am continuously following the testing and comments of BLUE ZERO, so I have collected some opinions (such as low-frequency distortion under louder pressure levels) and integrated them into the new RED ZERO. Thank you for your hard work @amirm, and all your opinions and comments.
Use case here...I love them.Curious how people use wired 3.5mm IEM these days given almost everything has gone wireless. I have old Sandisk Sansa mp3 players I use on flights, but without noise cancelling, I don't see a good use for IEMs on flights.
I am tempted to buy these, but just don't see a use case.
Are you gonna EQ them both to the same curve? I think that would be the most valid approach. And see if you can work out a way that you're listening at the same levels.That’s going to be my first test, once I get mine.
Ha, yes, except neither are controversial and both very similar!
The obvious advantage is simply that by supporting developers with money we keep the door open for them to bring even better products in the future.In practice the small differences in FR response between these and the originals look to be less than the differences you might experience by using foam tips vs silicones or a poor fit vs a good fit. I can't see any advantage of these over the original except the obviously better distortion measurements. But are these even audible? I mean at any normal level that is not so loud as to be damaging. I have the originals and even with bass heavy tracks played loud I don't notice any distortion. If I didn't own the originals I might prefer to buy the new version, maybe. But unless you listen at truly astonishing and deafening levels and have no access to EQ is there any advantage? I can't see it.
February 24 is around the corner !!!!!Sep 14, 2022 TRUTHEAR x Crinacle Zero
May 20, 2023 Truthear x Crinacle Zero:RED
It only takes 9 months for a new generation with notable improvement.
I’ve the same issue as you with IEMs so I use them seldom. The Truthear Zero (blue) are nice but I find them a bit too bass-heavy for my taste.The only problem I have with the Zeros (and with other IEM) is hearing my own breath and pulse far too loud.
It might not be just about FR, although it is obviously a very important aspect. I have bought the Hola, after having bought the Truthear Zero a little while ago after @amirm review.
To me the difference between what I hear from the Zero and the Hola, is a lot more than the variation in FR response. I am eagerly waiting for @amirm review of the Hola, hoping it will shine some lights on why they are so different. My money is on level of distortion, but TBH, I am clueless.
Alright, I don't know those FiiO's. Years ago I had Hifiman RE-400's and those were too big. Just went only headphones after that.Medium. Larger than the FiiO FH's.
