I think the Truthear Zero Red is too large for gym workout, and too expensive even at 55 usd to risk sweat damage.
Instead I would get a 7Hz Zero 2 for that purpose imo.
I don't think the tips are the problem, I actually reached into a tin can I have here with another bunch, and realised they have to be the wide bore kind, but the nozzle is nonetheless so thick that if it doesn't fit, there's no top that will help. The black foam was the best for me.Non of the ear tips fit my ear...
Do you have any recommendations for smaller ones?
That's fine, everyone won't like the same IEM. The bass boost is maybe 1dB too high for me, nothing crazy, but the treble needs to balance out the bass for overall balance. So the weak point to me is the overly relaxed treble. EQ can make Red sound competitive still IMO.I'm going to be a contrarian here, I've bought the 7Hz Zero 2 and these Truthear Zero Reds, and although I can understand why some would consider the Truthear's to be the better set, this is not my opinion (so I'm returning them and keeping the 7Hz, while still looking for a higher end studio IEM).
Here's what disturbed me:
1) The fit, took me a lot of experimenting to get them to sit deep enough for a seal, but not too deep where all I had was bass. Only the foam tip worked for me in the end, but it was always a little painful to wear.
2) The bass, touted as great, but to me it's just (a lot) of quantity with little quality. Plus I'm pretty sure I can hear something going on at around 150Hz, maybe it's the crossover, but everything around there was just played louder than it was. Add to that, it felt like very slow bass, lingering around and pushing everything above it down, vocals were super recessed. Even notoriously lean records sounded bassy, I don't believe they have much to do with the tuning of the 7Hz collab. That one has better quality bass, a little less sub but better transients and just a feeling of a very "correct" amount of bass.
3) Recessed mids and high-mids. This is the "break" for me in my few days testing, I cannot judge anything that's happening around 2-5kHz because it just sinks beneath that wall of misplaced lows. If I turn it up to the point in which I cannot work with audio anymore a few weeks later, maybe it evens itself more out, but that's irrelevant because the detail is just missing. To me they are worse than my good WF-C500 set (which only suffers from insane unit variance, one set was awesome and the other one had no lows and was super spiffy) as far as details go and quality of bass.
Naturally tested it with a 0.1 Ohm output in the studio, while working. I can understand and judge the mids and highs much better on the 7Hz one, and my impressions were almost always confirmed by my other references here. I could sort of make out some bass issues with them, but since the amount and quality is still rather unusable for critical listening, they're a hard pass for me. Kind of like a 90's boombox sound...
I will take the Kato off you if you are in the EU.Does anyone here have the Kato to compare the Red to?
I got the Kato and they are harsh and grainy in the upper mids lower treble.
I wonder if they have distortion there and if the Reds don’t have that
Thanks
The Red has lower distortion but both should be easily below the listenable threshold.Does anyone here have the Kato to compare the Red to?
Thanks
Did you try some different ear tips?
Also foam? That is to me always effective at taking ear canal resonances.Yeah I did. Didn’t make a diff at all.
It’s that peak.
You mean the foam ear tips included with the IEMs?Also foam? That is to me always effective at taking ear canal resonances.
