This is a review, listening tests and detailed measurements of Truthear x Crinacle Zero:RED IEM. It was sent to me by the company and costs US $55.
I was relieved that they are more mahogany/darker red than what the name implies. Compared to the previous Zero version, they are supposed to have slightly different frequency response and lower distortion. We will test both. Different silicone tips are included. Here are the sets I used for testing:
Measurement set was recommended by the company and are the same ones that I used for original Truthear Crinacle Zero IEM review.
If you are new to my testing, please watch this video on headphone measurements.
Truthear x Crinacle Zero:RED Measurements
As usual we start with our frequency response measurement:
That is very good match to our target with just a bit less bass. The original zero had slightly more energy in the 2 to 5 kHz:
Given the precise matching to our frequency response, the differential to our target is quite small and limited to bass:
Edit: there is an inline resistor which reduces sensitivity some but effectively boosts bass:
I was happy to see nice reduction in distortion:
That's incredibly low distortion even at 114 dBSPL! Love it....
The dual elements and crossover within cause non-flat frequency response:
Company takes advantage of this by including an inline resistor adapter which would cause more losses where impedance is low. This means you get less highs or put the other way, you get more bass, albeit with some power loss. I would not mess with the adapter.
Group delay is non revealing as is the case with most IEMs:
The Red remains in the class of less sensitive IEMs:
Truthear x Crinacle Zero:RED Listening Tests
I was so anxious to start listening to these but imagine my surprise when the first track sounded anything but correct. I quickly realized bass was not there and bam, I had forgotten to go to the next size up! Did that and immediate joy was to be had with accurate and deep bass complimenting the higher frequencies. The low distortion and detail gave me goosebumps sometimes.
I did find the sound a bit closed so I dialed in a low Q (2) 1 to 2 dB gain filter centered at 3 kHz. This substantially improved the spatial effects. But also caused some brightness at times. The designer expressed dissatisfaction with the original Zero's higher response and lowering it in this revision. I think the truth, pun intended, is somewhere in the middle.
EDIT: in the original review, I used the wrong target which showed great matching with target in bass. With the correct target, we see a bit of bass deficiency which would explain why boosting treble caused brightness.
Folks, we have another reference class IEM for hardly any money. Yes, there is a bit different tuning but whether that is better or not, is hard to determine given the uncertainty in measurements, and listening preference at granular level. I am happy with either but like the lower distortion in RED. If I want more spatial effects, I can dial up the mid treble. I could not reduce distortion the original Zero. So the RED gets my vote as to the better of the two by small margin.
It is my pleasure to add Truthear x Crinacle Zero RED to my recommended list. Skip a lunch or two out and put this in your arsenal even if you are not a regular IEM user.
Truthear x Crinacle Zero RED Harman Min EQ
May202023-214346
Preamp: -3 dB
Filter 1: ON PK Fc 33.26 Hz Gain 2.77 dB Q 0.27
Filter 2: ON PK Fc 8343.57 Hz Gain 3.1 dB Q 0.82
Filter 3: ON PK Fc 13467.71 Hz Gain -4.8 dB Q 4.74
Truthear x Crinacle Zero RED Harman Full EQ
May202023-214121
Preamp: -4.4 dB
Filter 1: ON PK Fc 30.26 Hz Gain 2.82 dB Q 0.27
Filter 2: ON PK Fc 155.16 Hz Gain 1.79 dB Q 1.82
Filter 3: ON PK Fc 909.79 Hz Gain -1.12 dB Q 0.27
Filter 4: ON PK Fc 693.18 Hz Gain 1.83 dB Q 1.77
Filter 5: ON PK Fc 2399.17 Hz Gain 1.83 dB Q 3.3
Filter 6: ON PK Fc 8437.11 Hz Gain 6.43 dB Q 1.18
Filter 7: ON PK Fc 8163.94 Hz Gain -4.71 dB Q 5.96
Filter 8: ON PK Fc 13464.71 Hz Gain -5.78 dB Q 4.74
Truthear x Crinacle Zero RED Knowles EQ
May202023-213853
Preamp: -9.8 dB
Filter 1: ON PK Fc 27.34 Hz Gain 2.91 dB Q 0.27
Filter 2: ON PK Fc 155.57 Hz Gain 1.85 dB Q 1.71
Filter 3: ON PK Fc 1062.22 Hz Gain -1.31 dB Q 0.27
Filter 4: ON PK Fc 701.33 Hz Gain 2.02 dB Q 1.77
Filter 5: ON PK Fc 2330.15 Hz Gain 1.32 dB Q 3.56
Filter 6: ON PK Fc 4090.86 Hz Gain -1.66 dB Q 2.64
Filter 7: ON PK Fc 13465.04 Hz Gain 10.78 dB Q 0.52
Filter 8: ON PK Fc 8221.25 Hz Gain -3.64 dB Q 5.91
Filter 9: ON PK Fc 13134.63 Hz Gain -3.55 dB Q 6.3
I'm in Aus. I ordered from their AliExpress store. No real need to wait for it to be on Amazon AU.Yep, waiting too until on Bezos.au
+1...Saw the distortion, then the price.
Purchased immediately.
'Geddes is a bit of a blunt Toole really'
Thanks! Could you do the same for the frequency response using the impedance adapter (no need for the Knowles target)?Here are some thoughts about the EQ.
Notes about the EQ design:
- The average L/R is used to calculate the score.
- The resolution is 12 points per octave interpolated from the raw data (provided by @amirm)
- A Genetic Algorithm is used to optimize the EQ.
- The EQ Score is designed to MAXIMIZE the Score WHILE fitting the Harman target curve (and other constrains) with a fixed complexity.
This will avoid weird results if one only optimizes for the Score.
It will probably flatten the Error regression doing so, the tonal balance should be therefore more neutral.- The EQs are starting point and may require tuning (certainly at LF and maybe at HF).
- The range around and above 10kHz is usually not EQed unless smooth enough to do so.
- I am using PEQ (PK) as from my experience the definition is more consistent across different DSP/platform implementations than shelves.
- With some HP/amp combo, the boosts and preamp gain (loss of Dynamic range) need to be carefully considered to avoid issues with, amongst other things, too low a Max SPL or damaging your device. You have beed warned.
- Not all units of the same product are made equal. The EQ is based on the measurements of a single unit. YMMV with regards to the very unit you are trying this EQ on.
- I sometimes use variations of the Harman curve for some reasons. See rational here: https://www.audiosciencereview.com/...pro-review-headphone.28244/page-5#post-989169
- https://www.audiosciencereview.com/...pro-review-headphone.28244/page-6#post-992119
- NOTE: the score then calculated is not comparable to the scores derived from the default Harman target curve if not otherwise noted.
- Occluding IE devices generally must have very good fitting/seal in the user's ear canal for best performance.
please spend a few minutes to pick up the best ear tip... Be sure to perform this step otherwise the FR/Score/EQ presented here are just worthless.- 1. more bass = better seal
2. More isolation from the outside world = better fit
3. Comfort
Good L/R match.
I have generated thre EQ, the APO config file is attached.
Score no EQ: 82.4%
Score Min EQ: 92.5%
Score Full EQ: 97.1%
All you probably need
Code:Truthear x Crinacle Zero RED Harman Min EQ May202023-214346 Preamp: -3 dB Filter 1: ON PK Fc 33.26 Hz Gain 2.77 dB Q 0.27 Filter 2: ON PK Fc 8343.57 Hz Gain 3.1 dB Q 0.82 Filter 3: ON PK Fc 13467.71 Hz Gain -4.8 dB Q 4.74
Over the Top...
Code:Truthear x Crinacle Zero RED Harman Full EQ May202023-214121 Preamp: -4.4 dB Filter 1: ON PK Fc 30.26 Hz Gain 2.82 dB Q 0.27 Filter 2: ON PK Fc 155.16 Hz Gain 1.79 dB Q 1.82 Filter 3: ON PK Fc 909.79 Hz Gain -1.12 dB Q 0.27 Filter 4: ON PK Fc 693.18 Hz Gain 1.83 dB Q 1.77 Filter 5: ON PK Fc 2399.17 Hz Gain 1.83 dB Q 3.3 Filter 6: ON PK Fc 8437.11 Hz Gain 6.43 dB Q 1.18 Filter 7: ON PK Fc 8163.94 Hz Gain -4.71 dB Q 5.96 Filter 8: ON PK Fc 13464.71 Hz Gain -5.78 dB Q 4.74
The following scores are not comparable to the others as the Harman target was substituted by the Knowles target.
View attachment 286809Code:Truthear x Crinacle Zero RED Knowles EQ May202023-213853 Preamp: -9.8 dB Filter 1: ON PK Fc 27.34 Hz Gain 2.91 dB Q 0.27 Filter 2: ON PK Fc 155.57 Hz Gain 1.85 dB Q 1.71 Filter 3: ON PK Fc 1062.22 Hz Gain -1.31 dB Q 0.27 Filter 4: ON PK Fc 701.33 Hz Gain 2.02 dB Q 1.77 Filter 5: ON PK Fc 2330.15 Hz Gain 1.32 dB Q 3.56 Filter 6: ON PK Fc 4090.86 Hz Gain -1.66 dB Q 2.64 Filter 7: ON PK Fc 13465.04 Hz Gain 10.78 dB Q 0.52 Filter 8: ON PK Fc 8221.25 Hz Gain -3.64 dB Q 5.91 Filter 9: ON PK Fc 13134.63 Hz Gain -3.55 dB Q 6.3
We don't know the distortion with the impedance adapter attached.The low distortion is impressive. I might be tempted to pick them up down the line, even though out of the box the response is a bit too similar to stuff I already have.
But slap an even higher ohm impedance adapter and possibly you get a stealth basshead IEM without getting the distortion out of control.
BTW, which tips are the right ones for you? The only problem I have with the Zeros (and with other IEM) is hearing my own breath and pulse far too loud.If I did not already have the blues, I would be purchasing these. The blues, with the right tips, are excellent.
A$82.99Yep, waiting too until on Bezos.au
It might not be just about FR, although it is obviously a very important aspect. I have bought the Hola, after having bought the Truthear Zero a little while ago after @amirm review.since already have 7Hz Zero and Truthear Hola, that out of the box are respectively very close
Is the housing same as the older model? Interested, if the nozzle is thinner now as previous model was so wide I could not find tips small enough for my ears
