Blue Meanie
- Joined
- Jul 26, 2022
- Messages
- 1
- Likes
- 2
Thanks, also on sale at Amazon in Europe, 42,49 €On sale now at Amazon for $42.49, I just ordered a pair using rewards points for $0 lol
Where did you buy them? You should be able to get a warranty replacement if they died that fast.Mine stopped working, the right dynamic driver of 10mm stopped working, I'm so sad, I just used them for a little more than 1 month, I hesitate to rebuy a pair or buy the tangzu waner for cheaper... man, I will miss the bass of the crinacle truth hear zero
Amazon should cover it, EU law mandates a two year guarantee for faulty goods. https://europa.eu/youreurope/busine...s-guarantees/consumer-guarantees/index_en.htmbtw I contacted truthhear and explained the issue to them, I hope I will get a replacement soon, I'm consoling myself using the sennheiser HD-25 II, cause it kind of give me a similar feeling than IEM cause the headphones is pushing on the ears quite a lot and is closed back, and by this means there is so much detail retrieval in the music, reminding me of the truth hear zero, even though there is no real correlation between the two.
If the shipment was done by Amazon, you just need to contact the customer service. Usually you'll get a refund and can buy them again. It's not difficult.btw I contacted truthhear and explained the issue to them, I hope I will get a replacement soon, I'm consoling myself using the sennheiser HD-25 II, cause it kind of give me a similar feeling than IEM cause the headphones is pushing on the ears quite a lot and is closed back, and by this means there is so much detail retrieval in the music, reminding me of the truth hear zero, even though there is no real correlation between the two.
Your graciousness is noted!I agree. It's 100% awful for you.
You definitely will! I use mine practically every day.Just got a pair of these and I can't believe how good they sound for the price. I think I will enjoy them very much!
It's the Zero with slightly more bass and the upper mid rise pushed back slightly, which makes it a bit less shouty/forward. Slightly- it's very similar. I prefer it over the Zero, although my Zero has channel imbalance with reduced bass on one side, so the Khan is more for me maybe than most. I think Hi-Fri did a teardown and they looked identical inside, both the drivers and the crossover.I would love to hear more abotu those that have the Kahn and the Zero. I really love the Zero, in fact it might be my favorite set even over the Ikko oh10s...I have enjoyed the tuning of Hbb collabs before and the Kahn seems to be really similar if not identical to the zero.
I have a Topping A90 but use dongles for IEMs. Truthear Shio, Moondrop Dawn are good options. It's an IEM, it doesn't need a high power headphone amp.Hi everyone, just to let you know, I couldn't return my zeros so I just bought another pair, they're not so expensive so it's no a problem for me, but I suspect that it might have been my topping L30 who destroyed the driver on the right channel of my first pair of zero, I think next month I might be buying a new amp for my zeros, my dac is the gustard X16, any recommendations for a solid state amp who could match with my gustard dac which is very analytical and also match with the zero's in terms of impedance output ? I thought about the topping L50 or L30 II ?
When I said that the gustard DAC x16 was very analytical, I really meant very detailled because of the dual dac chip especially with the L fast filter modeWhat's an analytical DAC?
