Impressive. I'm tempted even though I don't really need them. Searching for this took me to this ranking list of many, many IEMs. I can't believe the price of some of them! <https://crinacle.com/rankings/iems/>This is a review, listening tests and measurements of the Truthear Crinacle Zero IEM review. It was sent to me by @crinacle as he has been a consultant on the project. It costs US $50.
I like that it has a bit of "bling" but not too much. The cord is just the right length for me (many IEMs are too short for my use). It is super flexible with very little microphonics. You get two sets of silicone pads in three different sizes which suites me fine. I wear the largest one and it stays nicely put.
The claim to fame of this IEM is that it complies with the Harman target. Let's see if that is the case.
Truthear Crinnacle Zero IEM Measurements
Let's start with our frequency response measurement:
I must say I was not prepared for such a tight fit to our target! Other than a hair droop at 20 Hz and a bit deviation here and there, the response hugs our target a wet towel! Very nice. This renders our difference frequency response kind of useless:
Distortion is good enough at lower levels but gets a bit much at maximum SPL:
Group delay is not revealing for IEMs and such is the case here:
Impedance shows evidence of some tuning in bass frequencies:
The low impedance means many amps and sources can drive it but it is very low. Sensitive is on the low side as well for an IEM:
Truthear Crinnacle Zero IEM Listening Tests
As usual I start with my female vocals. My first reference track had excellent warmth courtesy of proper low frequency response. This continued from track to track with tonality that was just delightful. It not only sounds "right" but also enjoyable. The sound you get is like the best speaker in best room with no room modes. Of course there is no tactile feedback so deep bass doesn't sound the same but you get the picture.
I cranked up the volume on it and it kind of gets loud but I thought the bass started to gradually get distorted. Not a practical problem as you are not going to want to listen at those unsafe volumes.
I am sitting here typing this review and listening to it and marveling how nice every track sounds!
What on earth are you doing reading the rest of this review? Go and buy one of these! I don't care if you don't listen to IEMs normally. You want this IEM so you know what correct tonality is, when you listen with other transducers such as headphones and speakers. Think of it as the tuning fork that a musician uses! This IEM needs to be in your arsenal.
For those of you who use IEMs as I do in summer months (headphones wear too hot), you are in for a treat for peanuts out of your pocket. The science works. Kudos to @crinacle for advocating this execution. We are indebted to you for your contribution here.
I am happy to strongly recommend the Truthear Crinnacle Zero IEM. It brings that incredible harmony of technical excellence and superbly low purchase price.
Yes if you have one of those (usually gold) 3.5 to 6.35mm plugs that come with most headphones. These will come with the smaller 3.5mm plug- dunno if they ship an adapter but unlikely but they cost £1 or so from amazon.Please forgive this dumb question. Could these be plugged into my hifi, instead of the Beyerdynamic DT770's?
The latter use a full size rca pin, is it? I suppose I'm asking what is the plug on these iem's?
And, would there be any point, sound qualitywise? Thank you.
I'm using an Apple dongle with these and it's plenty loud.OK, purchased on Amazon. Opinions please: do these need a dedicated headphone amp? With low impedance and sensitivity, would the headphone jack on my TEAC AI 301 DA do them justice?
94...104...114 dB...?Distortion is good enough at lower levels but gets a bit much at maximum SPL:
Thanks JimboYes if you have one of those (usually gold) 3.5 to 6.35mm plugs that come with most headphones. These will come with the smaller 3.5mm plug- dunno if they ship an adapter but unlikely but they cost £1 or so from amazon.
SQ wise, depends on the output impedance of your headphone plug on the hifi. With these being low impedance there might be some interplay affecting the frequency response- for better or worse depends!
BUYING IT NOW, thanks @amirmThis is a review, listening tests and measurements of the Truthear Crinacle Zero IEM review. It was sent to me by @crinacle as he has been a consultant on the project. It costs US $50.
To the UK, no.Do we know if there will be duty and or VAT to pay on these? (Plus shippers processing fee)?
£50 is an impulse buy £70 not so much.
Well, I guess reproduction of sounds is basically trying to imitate reality. If Steinway Grand piano does not sound like Steinway Grand piano, then this is false interpretation of reality.
Yes and then the problem is with the recording and not with the reproduction device. Plus there is no way that any reproduction device can add information which hasn’t been captured by the recordings. That would be magic or also called snake oil.Aren't they reproducing a recording rather than reproducing reality? What if the recording doesn't sound like a real Steinway?
I think this is a common misunderstanding. It's late and I'm running out of steam, but if I can explain it simply the reproduction of sound fundamentally really has nothing to do with "imitating reality" even if that is yours, mine, and many other's expectation. It is about reproducing a recorded/contrived/mixed/mastered/whatever signal so that the response of said signal is identical or as close to identical at a certain point in space, or at least the intended response at a certain point under certain conditions.Well, I guess reproduction of sounds is basically trying to imitate reality. If Steinway Grand piano does not sound like Steinway Grand piano, then this is false interpretation of reality.
This is the one thing making me think a bit before buying them. The problem with MMCX connectors is that they're fragile and easy to break unless you use a tool to pry it off (and people have broken them even with a tool). But at least it's standardised and universal. 2-pin connectors come in at least 4 different flavours: 0.75mm, recessed 0.78mm (which is most common and seems to be the one used here), shrouded (QCD, rounded corners) and shrouded (TFZ, square corners).A shame it's 2 pin![]()
