Finally managed to get my Pure delivered.
First quick impressions:
- As i suspected from previous Hexa experience, still some fit issues: I usually have to use large tips to get good seal with many iems but with Pure i have to scale down to smaller ones, probably due to their nozzle length and internal body shape. At the moment i got a nice seal with Tri Clarion Mid tips, but this brings up some other considerations (see below)
- I have to rotate the iems backward a lot to get good seal, something I usually have to do with all iems due to my ear canal angle, but Pure need more than the ear-hooks of the cable permit, so i have to straighten them a bit or try a different cable.
- With good seal and small bore tips, like TRN T, they sound great, very neutral and warm as i was expecting and searching, but not dark. Unfortunately with that tips they tend to slowly loose seal with normal jaw micro-movements. With Tri Clarion M the seal is perfect and steady, but the sound seems a bit muffled. Tri Clarion have very wide bore and I think my experience matches with what Crinacle measured
5db in that 8k-10k range can make a difference in an already warmish iem.
These are very quick impressions, I have to fiddle more with other tips and the ear-hooks, anyway I think i can get them right.
[EDIT]
It seems I managed to get a good result with these super cheap no brand tips i got long ago
just like it was for the Zero:Red
For my ears both IEMS seem to need slightly longer tips, the Large sized of these ones are 10.7 mm long while most of the ones I normally use are around 9-9.5mm (TRN T, Kbear 07). Tri Clarion also are around 9 mm long but their peculiar shape makes up for it.
