We'll see, mine is on the plane.This one is not so excited about the Gate.
looks pretty good. When I saw the tiltle of the thread, I thought it'll be some watergate story about TruthEarTruthear Gate was announced, no pricing yet. I guess it may be the Hola successor as entry level 1DD IEMs. Graphs very close to a Red, which is great news imo.
Too bad, what specifically went bad?Hope the Gate will be more solid than the Hola, I had two of those going bad in less than one year.
The particularly troublesome usecase seems to be sleeping with IEMs. Quite often one of the IEMs goes bad: i.e. at first it starts getting quieter and quieter and sometimes goes full silent. Most of the time it is the right ear/side .. no idea what am I doing in my sleep to cause thatToo bad, what specifically went bad?
oh well, I hope mine lasting long, use them rarely and only at home and never sleep with iem.The particularly troublesome usecase seems to be sleeping with IEMs. Quite often one of the IEMs goes bad: i.e. at first it starts getting quieter and quieter and sometimes goes full silent. Most of the time it is the right ear/side .. no idea what am I doing in my sleep to cause that
The new lowcost asian IEMs seem to be particularly bad, some died after just a few weeks. The Holas were among the worst. But I had some that worked fine up to 2 years
Just received my Gate. Boy do they feel cheap compared to the Hola.
The shell seems to scratch very easily. My left Gate has scuffs from the factory:
View attachment 373867 View attachment 373868
Also, there's a somewhat disconcerting hole in the plastic shell which leads straight to the exposed driver:
View attachment 373864 View attachment 373865
Strongly suggest not using them anywhere near moist environments.
This is my problem with the $20 market. They can sound as good as you like but if they feel awful and /or break easily it's a complete false economy.Just received my Gate. Boy do they feel cheap compared to the Hola.
Edit:
The new cost-cut, injection-molded shells make the GATE 30% lighter:
View attachment 373870 View attachment 373871
The cable is identical to the Hola, so that's nice.
Thanks for the heads-up!PS.
Beware of your posted pics, we can get your fingerprints and steal your identity
Hola's hole (no jokes intended) is on the inner side and doesn't go all the way through to the outer face, or at least it's closed by the metal faceplate. If it's there I suppose it's has it's function for venting\tuning, sure it's seems a bit exposed.@staticV3 Hola seems to have the exact same unprotected hole in its shell.
I received the KZ Libra Balanced ($12) a few days ago and yes they look cheap and are nearly weightless but they are well made, sturdy and comfortable, I actually prefer them (sound wise) over the $120 CCA Hydro which are built like a tank but they are uncomfortable, big and heavy.This is my problem with the $20 market. They can sound as good as you like but if they feel awful and /or break easily it's a complete false economy.
There is no hole on the faceplate of the Gate. I’m not understanding what you are saying here. The Gate and Hola housings are essential the same design, just differing materials and production methods. Both venting holes are in the same spots and same size on both. Both faceplates are sealed with no exterior venting. You just can’t see inside the Hola’s opaque faceplate to have known how obviously open the larger back vent hole is.Hola's hole (no jokes intended) is on the inner side and doesn't go all the way through to the outer face, or at least it's closed by the metal faceplate. If it's there I suppose it's has it's function for venting\tuning, sure it's seems a bit exposed.
