Truthear GATE $17 IEM Review
Rate this IEM:
    Votes: 11 2.9%
    Votes: 9 2.4%
    Votes: 29 7.7%
    Votes: 329 87.0%
Got my pair this weekend. I prefer the Zero2 (probably because this is what I use every day) but no problem at this cost.
One annoying point is the fact the gate is not able to be plugged with the balanced cable I use for the Zero2, the hole inside the plastic part is too small. Not a question of sound quality I am able to hear, but a question of convenience with better quality cable with no knots.
So after owning a pair of Truthear Gate a year my mic-cable, or perhaps the buttons more precisely has started to live their own life. At times they will just press randomly, even if I barely move, triggering play/pause, track changes and some annoying voice assistant that I've tried turning off completely on my Android but it's still there for some reason.
Don't know if it's bad luck or the cable in general with these that sucks.
I've ordered a new one, lets hope it lasts longer than a year!
Apart from that, I love these things! I had a pair of Zero 2 before but I prefer these things, mostly because of the cleaner and more subtle looks. Soundwise they're close enough for me to not care. Having that said I do EQ them quite precisely to be flat using a Jcally JM20 Pro, but plugging them into my phones 3.5mm port with no EQ (or maybe sometimes a low and high shelf for some overall tweaking) still sounds great, even quite loudly!
By what measure?
I too love these things to bits. Shortly after my last message in this thread my then current pair died, one side got quieter than the other and no amount of isopropyl alcohol dosing and tweezer surgery would resuscitate it. Had a few other pairs of Gates at home so I just threw the now dead pair in the electronics bin, it lasted a long time, and then I bought ten more pairs for less money than I'd pay for a halfway expensive pair of IEMs.
I purchased both the Zero2 and GATE at the same time, opened and used the Zero2 first, and have not even worried about the GATE as the Zero2 is practically perfect. Looking at the profile of each, the Zero2 seems more likely to have a bit more bass, so I never even considered using the GATE.
By what measure?
By Amirs measure. Sure the high end is a bit unsure but the low end is easily EQd.
My Sony WF1000XM4 that cost ten times more than these also got one side that started to get quieter after about two years and at around the same time got a bad battery. Managed to swap out the battery but not fix the quiet bud. Won't be getting a new pair of those!
And fyi my first pair of Zero 2 also got a quiet earbud. So sure it would be nice with better build quality of these things, but seeing one can't even trust a pair 200 EUR bluetooth earbuds it all feels like a gamble anyways.
You might have clogged the nozzle filters with earwax. I saved a few earbuds from the same issue by simply removing the filters with tweezers.
How do these sound, subjectively, vs your Sony WF1000XM4s?
Yeah I have checked, but it's unfortunately not as easy as that.
With no EQ the Sonys sounds like crap, it's muddy with to much upper bass while lacking lower bass and much of the treble. With EQ they can be quite close, but can't play loud enough for me since I need to EQ them quite hard.
Also when walking there's too much noise from your steps which I find really anonying. The ANC is great though which makes them preferable when traveling, but seeing I rarely do it I can't be bothered to try to fix them or buy new ones.
To Harman 2019 then? I was pulling your leg a little, if one EQ'd IEMs to flat then they would sound pretty bad. :)
Ah yeah of course, "Flat" to a Harman :) Would be a fun test to EQ something to completely flat, actually a bit curious how it sounds!
My Gate IEMs just arrived to replace a pair of Reds that I lost. Paid £10 shipped to UK with an Aliexpress discount code. The silicon tips fit really well with a nice tight seal. From memory the sound is more open and detailed than the reds. Quite unbelievable value. Thanks for another great review that has saved me £££ (which is becoming a theme with ASR purchases)
Hello, new here
I made an account just to message here. My Truthear Gate filters needed replacing so I was wondering if there were any official channels to buy the filters or if 200 mesh is enough to get a similar enough sound as if it were not modified. I'd appreciate any responses :D
One more thing, what size should the mesh be?
According to Nozzledb the bore is 5.38mm and the lip is 6.2mm, should I be going for something about 5.5mm?
Are they clogged? I would strongly suggest trying to clean them however necessary, without taking them out. I had this issue and the filter is an essential part of the tunning. I don't think any other filter will serve without changing the sound for worse.
Pretty sure they are. How did you manage to clean them without taking them out?
I tried using a drenched alcohol qtip by applying it on the metal bit pointing down, left it there to dry and after an hour it was still clogged so I tried to remove the mesh to clean better.
I'm not sure I'd be able to fix it now with the way I've tried cleaning it unfortunately, really did myself a solid there
Hydrogen peroxide can dissolve earwax, but I don't think alcohol works as well. Risky because it's more water than peroxide but if you are willing to give it a try it might work for this cleaning task.
I would strongly suggest try to clean it as much as you can without taking the mesh, because it's very hard to put it back. I took mine out and I was not able to put it back. The sound without it is very bad. I ended up buying another pair.
