kemmler3D
Wow, I just paid more than this for a plate of tacos. (Tourist trap)... Still. Really impressive outcome for the money. Pretty much a no brainer if you're in the market for some cheap earphones.
I suggest you to use a computer and their Remote app, which makes setting up EQ and saving a trivial task.Oh jeez, @amirm just "made" me spend $17, lol. Now to decide whether to dig out the RME manual and struggle through setting up the EQ there, or simply dial it into the WiiM's lovely GUI...
I own the reds, they just don't fit my ears good at all...I think more information is required to give an appropriate answer to this type of question.
Are both comfortably within your budget? What have you used previously and did you like or dislike them?
Except that they don't provide a Linux version, or a nice Chrome extension...I suggest you to use a computer and their Remote app, which makes setting up EQ and saving a trivial task.
See below:For the most part I am using the Sennheiser IE300. Anyone compared those?
Simple. Made in China and IEM part prices are not very high and they're very small.How is it even possible to make a profit at that price point? Will order one out of curiosity. Thank you, Amir!
I filtered it out but could not tell a difference. If you are much younger then me, then you may need something there. Note however that such a resonance is dependent on your ear anatomy so no measurement is going to predict that accurately.My only concern is that peak at 15K, is it harsh?
I couldn't agree more. Obviously, for $17 is quite some good sound, but probably only worth it if you just have that amount to spend. Build quality looks cheap and design is low profile. And while the compliance to Harman is quite good, the peaky treble will be hard, probably even impossible to fix with EQ. This is where it still is worth to spend a bit more, get for example the Truthear Nova and have better sound (even without EQ) and don't worry anymore. Even if you want to EQ to another target, with a smooth reponse this will always be possible.Sounds worse than the Zero:2 to me.
Treble response is peaky and hard to adjust to preference, and upper mids are accentuated and sound honky:
Additionally, the Gate feels extremely cheap in the hands.
The housing is bottom-of-the-barrel injection-molded plastic, on par with those $3 KZ IEMs from AliExpress.
A stark step-down from the resin printed housing of the Truthear Hola which this one replaces.
You might think that a smooth measuring IEM above 3kHz will be more likely to produce a smooth FR in your ears. Realistically, the physical conditions can't guarantee that:I couldn't agree more. Obviously, for $17 is quite some good sound, but probably only worth it if you just have that amount to spend. Build quality looks cheap and design is low profile. And while the compliance to Harman is quite good, the peaky treble will be hard, probably even impossible to fix with EQ. This is where it still is worth to spend a bit more, get for example the Truthear Nova and have better sound (even without EQ) and don't worry anymore. Even if you want to EQ to another target, with a smooth reponse this will always be possible.
I have trouble seeing or feeling the housing when I'm listening to it!Additionally, the Gate feels extremely cheap in the hands.
I turn 60 this year. What, exactly, is "treble" again? I can't seem to remember hearing it.I like my pair, especially compared to the older Hola. Still, they don't get much daily use, as some have alluded to in this thread, the treble is hard to keep under control if one is sensitive to hot treble. But, at the same time, it is a major improvement over the older Hola in this regard.
