Truthear GATE $17 IEM Review
Rate this IEM:
    Votes: 10 2.8%
    Votes: 8 2.2%
    Votes: 25 7.0%
    Votes: 313 87.9%
Something seems off? The bass on these two tests seems contradictory to your data
This does not track with Amir's measurements here, which show the Chu II as closely tracking the target and the Zero:2 being somewhat above the target.
If you looks closer to these graphs then you'll notice that this is just the way the graphs are aligned - it seems that bass level is the same or even higher on Zero II - until you notice that an area from about 400 Hz to 1 kHz follows Harman curve on Zero:2 graph and dips below it on Chu II graph. I aligned both graphs on Squiglink at 1K to make the difference obvious. Of course, you can align at bass and then say that Chu II has dip in mids - which is really the same thing, with the same end result - bass overshadows mids to some extent and sounds bloated. Note that Zero:2 already has a bit of high bass excess which doesn't yet sound bloated to me, just "warm". I prefer to EQ it down a bit (as in Amir's EQ) but I can perfectly enjoy listening to Zero:2 without any EQ. BTW, Amir in his own EQ also pulls down a broader region of bass in the case of Chu II.
And no, the more likely explanation is a seal issue or that it's in your head. +/-2dB has never meant the difference between "perfect" and "unlistenable" no matter where on the spectrum the variance occurs.
Hmm, I think there is some confusion here. Zero:2 vs Chu II - I can listen to both without EQ, I prefer Zero:2 (mainly because of the bloated bass on Chu II but not only).
Gate, however, is a different story - it doesn't only have more mids and lower treble, it has notably less bass, this combination makes Gate stock sound without EQ annoying to me. As in physically irritating. Quite possible simply because due to the lack of bass I raise the volume to get bass to the level I prefer and then the higher frequences become too loud. So, yeah, simply unlistenable without EQ for prolonged periods.
Of course, with EQ (e.g. Amir or Maiky76) they all sound significantly more similar to each other. Still, I prefer the sound of Zero:2 even after EQ.
GATE's shape makes the units sit just a millimeter or less deeper in the ear than the Zero:2
Interesting. Certainly other way round for me, tips that work on Zero:2 just don't seal with Gate, I needed bigger ones. :)
Adjusted the EQ filter provided by Amir a tiny bit to counter some slightly overbearing (mid) bass on a select few tracks, to 140Hz, 2.0 dB, Q 0.72. Looking at the graph, the downward slope of the bass filter indeed seems to overshoot a bit past 200Hz (from where the volume of mid bass is already enough). To my ears the slight bit of "bloat" that could occur is gone now, without the fullness of the bass being sacrificed. It's pretty much perfect now!
Very interesting:
The GATE has quite a lot of bass for me straight out of the box - not quite as much as the Zero:2, but very close. The main differences I hear between them is their balance between bass / mids / highs. So yeah, certainly the opposite situation for me, which I guess only points to seal and driver position variations.
Just went back and forth with the Gate, Zero:2 and a KZ ZVX Pro. Much to my surprise the latter is pretty much equally good, but without any EQ. There is very little measurements available but I suspect it would measure quite well. I hope a pair lands in Amirms hands at some point.
..the premiumish metal build is a plus, the dubious reputation of KZ is a minus.
From graph ZVX Pro seem very alike EDC Pro and EDX Lite (a tad less bassy), I own both and can confirm they are very well tuned and a bargain for the price (EDX Lite often around 3€ ).
Using foam eartips made a huge difference. For the better that is. ;-)
I always liked--and usually preferred--foam tips with smaller body IEMs such as Etys that can be angled as needed to fit deeper and seal more reliably. I have some large size Comply tips that worked great for me with a Hifiman large-nozzle-but-small-body dynamic that fit the Gate nozzle, but I can't get a good seal with them on the Gate. The body of the Gate is too large to allow me to angle them for deeper insertion. Just another example of all the trial and error required with IEMs and tips.
Ok, these are absurdly good. I just changed to my preferred S&S tips, plugged into the old E50/L50 stack and put on "Transmutation (The Constant Change Of Everything)" by Karmakanic, using Roon's eq preset for the Gate, and discovered I could not want for nor do anything but sink in for the next 23 minutes of bliss.
At under £18 this is nuts. I might start forcing them upon friends and family.
Apologies for my off-the-cuff subjective audiophilesque anecdote, but for my ears at least, the science goes undisproven. Good job gentlemen who got us here. Thanks for the review @amirm !
I have had great success with some foam tips by putting them on the IEM backwards, sort of butt first. If your foam tips are cone shaped or parabellum style tips, it's worth a shot. Don't know if this applies to your problem, but it's a free trick.
I just got these, the Truthear Gate ($22.14 with tax on Amazon), and the JCALLY JM20MAX DAC ($16.57 on AliExpress). I also purchased Wavelet ($4.99) for EQ on my Android devices. All in I spent $43.70.
I am floored at the sound quality that amount of money gets us these days. Wow!
Plenty of headroom for an intense sub bass boost with the JM20Max :D It'll to loud enough to risk almost immediate hearing damage, so please be careful!
Movies are pretty nice that way.
You don't need to pay Wavelet for autoeq functionality, did you need the extra features?
Mine came with 4 pairs of tips, ranging from small to large. They were in the bottom of the box, under another piece of cardboard. Did you get them with yours?
Yes, they were in the box. None of them gave a good seal.
Which makes these inexpensive IEMs all of a sudden quite pricey.
I must say I disagree.
