I will try once more, and then I will give up with you:
From my first post, I never said anything about distortion of the kind of digital clipping.
It was all about the small speaker.
Let’s say that the owner enjoys his music at Xdb average, measured at the mids.
As you say, the MF and the HF (and the midbass) will be attenuated by 6db.
Not the area 45-70Hz. This will not be attenuated.
At this level, after the filter is applied, in order to play at the same desired level as before, the rest of the spectrum will play +6db from the point of the attenuation, so -6+6=0. No problem here.
The midwoofer will be forced to play 6db louder between 45-70Hz, to catch up, but will start from 0, not -6. So +6db.
You said it yourself:
And with small midwoofers (it’s a 6 inch, isn’t it?) there is no headroom available to lose at 45-70Hz.
This is the measurements of the Monitor Audio Silver 6, with 2 6inchers, and much bigger cabin. Check the distortion at 90db.
Do you think that the Siver 1, will have any headroom available after the filter?
