You also have to be careful with power ratings. Speakers are rated for "normal program material" so a "100W" speaker is supposed to be safe with an amplifier hitting 100W on the musical peaks, with maybe 20W average. If you play 100W continuous test tones into it, you can burn it out! Even worse.... A "100" tweeter is rated only for the high-frequency part from a 100W amplifier which is much weaker than the midrange and bass. If you open a regular music file in Audacity and apply a high-pass filter, you'll notice the wave gets "smaller". the higher you go, the weaker the signal. It might seem misleading but a tweeter or super-tweeter manufacturer can legitimately specify a higher power rating by simply specifying a higher crossover frequency.
One thing that might help to protect the tweeter at extremely high frequencies is that the speaker/tweeter will probably become inductive (higher impedance at higher frequencies). That means less power with the same voltage.
Also, high frequencies are attenuated/absorbed in the air more than lower frequencies. Over short distances it shouldn't be a problem but from what I've read, with the distances in a movie theater there is a few of dB attenuation at the highest audio frequencies. (Of course they don't care about ultrasonics in theaters but it would be worse.)
