AceOverlord
- Joined
- Jul 31, 2025
- Messages
- 6
- Likes
- 1
I recently started setting up a project where I'm trying to record and playback high frequency sounds. I went ahead and purchased the Taket Batpure super tweeter.
Edit:
Didn't realize there was so much hate against super tweeters. Admittedly, I was a little curious when I first heard about them. But rest assured, I don't buy into the hype and I'm trying to set this up for some animal based research. Perhaps they caught on because they look pretty cool on top of speakers
For the most part, the microphone setup is working from what I can tell, the capsule is recording frequencies all the way up to 98khz. Allegedly, I've only got one digital preamp. Recording and playback at the same time has introduced noise from playback into the recording.
I went ahead and made a test sweep that goes from 0 to 100khz, and recorded the output. When I play it back through the speakers and record it, I notice I'm not getting much sound from the supertweeters. I followed the manually and connected them inline to the back terminals of the bookshelf speakers. Cranking the volume to max, I'm not registering really any sound from them. I'm definitely getting frequency data on the spectrograph up to 100khz, however there is no significant volume. (less than the ambient volume of the room, which admittedly is pretty bad)
I've come to the following conclusions. There is something I'm overlooking, for example, maybe the amplifier has a huge frequency falloff over 20khz, or maybe even a lowpass filter (the exact range the batpure chimes in) (It also says in the manual that its rated for 20,000khz)
Or maybe the batpure supertweeter can't produce any noteworthy audible sound being low efficiency at 70 dB @ 1m. Here is what the recording of only the batpure speaker at 1 inch away looks like at max volume.
Note: the sharp frequency line is partially noise from the preamp. I need to isolate them to get a true recording.
The official high frequency equipment is so darn expensive, but my end game goal is to properly replicate a high frequency recording up to around 60khz. I don't necessarily need hi-fi sound on the higher frequencies, but somewhat stable volume.
I would really appreciate it if anyone can point out where I may have gone wrong or what I can try next. Trying to keep my budget to around 500$, but that may not be possible.
Notes: if I edit this post, they will be here.
I used stainless steel screws as terminal screws, however I did try wiring it directly with no improvement.
I also tried shorter speaker wire, around 3 feet.
Edit:
- Yamaha km-208 (Frequency response 200khz according to the manual)
- klipsche SB1 bookshelf speakers
- Behringer umc202hd - USB Preamp with 192khz
- Laptop
- Taket Batpure - (3D printed cat shaped mounts just so they look cooler)
