Trinnov Optimizer and Calibration measurements
Bartok
Hi,
I'm a Trinnov Amethyst owner.
This weekend i did some changes in my livingroom, with the need of new rounds of optimizer/calibration.
I run The optimizer like Bi-amp 2.0. With my front speakers and 2 Bass towers.
I run several rounds of optimazation with different crossover points. (80hz,120hz and 150hz)
But what i started thinking about.
At advanced settings, Optimizer settings and Calibration. There are only 1 measurement.
Is this always the last Measurement done? Regardless of what Preset is choosen.
If so are the crossover point on the last Optimizer Measurement now affecting all other presets? (The active Crossover are correct under each Preset Settings)
Maybe it's also a easier way to play with crossower settings without need of running new full optimaztion wizard and measurements?
Hi Bartok, I am also an Amethyst owner.
Bass management is applied after the measurement. The optimizer system takes a measurement and "recommends" a crossover point based on its measured and predicted room response. You can then change this on the fly to your own preference. That said, you can make a series of measurements and save them individually somehow but, unless you are moving the kit from one room to another, then why would you want to is my thinking.
Regards
Chris
