musicforcities
- Joined
- Sep 18, 2021
- Messages
- 472
- Likes
- 569
Well. That is very impressive power and performace in a twelve channel amp. And price seems reasonable given that and its intended market.
I am one. Planned for 7.1 system and now facing having to have more channels for ATMOS. My rack is waist high and is already pretty full.So people have a whole spare room to build a huge home cinema, but then can't spare the space for another 1U enclosure? I wonder how many of the actual customers are in this particular predicament?
I'm considering upping from 5.1 to 5.1.2. So the top-middle overhead speakers are preferred over front-heights?A top-middle over the listening area if it’s a modestly sized room adds a lot. I would say that a 5.1.2 is more enjoyable than a 7.1.0 with a lot of the Atmos content being mixed right now in many HT rooms.
No, 1st thing would be front heights.I'm considering upping from 5.1 to 5.1.2. So the top-middle overhead speakers are preferred over front-heights?
I was sort of reluctant to move to Atmos for music. Despite all the obvious theory that it is the superior format. But with the new setup I gave it another try and I really like it much better than stereo. At least for native productions such as the new JamieXX albumI definitely like to add Atmos support. We built the theater a decade before the format came out so the idea of ceiling speakers was not in sight. On a hunch, I put in wiring for two rear ceiling height speakers. So those are relatively easy to add. The second pair will be much more difficult. I hope I can figure out a way to do that as well.
It‘s 16 CH…Well. That is very impressive power and performace in a twelve channel amp. And price seems reasonable given that and its intended market.
Please note that only the ALT32 has DB25 connectors; the ALT16 has balanced XLR out and is ready for Audio over IP via Network RJ45 connectors, but that’s not ready yet.Couple of remarks to Amplitude - amplifier is optimized to be paired with Altitude AVP and is cheaper of 2 concepts (Amplitude 8 has 8 hypex1200 modules with LPS).
Gain matching gives audible advantage to the system, DB25 connectors are very comfortable to work with, you cannot underestimate how much better it is to handle 2 cables instead of 16. Ability to bridge the channels gives another level of flexibility. e.g. in 9.x.4 setup you can bridge l-c-r for more power.
And to bring things into perspective, you expect to see it paired with Alt 16 that costs around 18k eur, and if you get both, you can expect to get some good deal.
That's pretty easy to decide - cause ATMOS tells you what to do to stay within the norm so the decoder knows what to do ;-) Search for "Atmos-installation-guidelines-....pfd"I'm considering upping from 5.1 to 5.1.2. So the top-middle overhead speakers are preferred over front-heights?
I have asbestos in the ceiling, I think Atmos is out for meI definitely like to add Atmos support. We built the theater a decade before the format came out so the idea of ceiling speakers was not in sight. On a hunch, I put in wiring for two rear ceiling height speakers. So those are relatively easy to add. The second pair will be much more difficult. I hope I can figure out a way to do that as well.
Opps sorry. Ok even more impressive then. I would imagine these are intended for full custom home theater installs or audio distribution.It‘s 16 CH…
Why do you need an amp at all?For me the perfect amp (unicorn) would be a 32channels with Dante and Ravenna input, passive cooling and little to no heat and no more than 350mm depth. All my speakers now are active (2 channels per speaker) so a 32 channels actually becomes a 16 channel device.
Sorry for the confusion. They have "active/digital/external" crossovers but no internal amp. I'm not sure if I can name these "active" speakers.Why do you need an amp at all?
A Neumann MT 48 or a mergin anubis can distribute the aes67 channels that are decoded in a mac (pc?)..
Thank you for your review! Are we talking 50 points or more?This is a review and detailed measurements of the Trinnov Amplitude 16 home theater amplifier. It was sent to me by the company and costs US $12,500.
We have an on-off switch and a faint display that shows whether the channels are bridged or not. Given the main application of being in a dark room, you wouldn't want any bling on the front. Back panel shows the amazing number of channels crammed into this enclosure, courtesy of ICEPower class D amplifiers and custom power supply:
The binding posts show up impressively. And dual AC input (both must be used) hints at the box delivering 16 concurrent channels of amplification (or 8 bridged -- not tested). Inputs are provided through DB-25 connectors. Trinnov supplied me with a very supple and high quality converter to XLRs which made testing easy.
Trinnov Amplitude 16 Amplifier Measurements
I performed all of my testing on channels 1 and 2 in single ended/non-bridged mode. Let's start with our dashboard:
Nice to see the unit meet and exceed the spec on noise+distortion. Performance is not quite as good as the Trinnov 8m I tested but still quite competent:
Gain is on the low side but that is intentional to maximize SNR by matching the Altitude 16 processor. Speaking of SNR, performance is excellent there:
There is no load dependency which is nice:
I tested using reactive loads and it delivered the same.
Multitone shows some rise in distortion at higher frequencies:
Which then gets reflected in intermodulation distortion using 19 and 20 kHz tones:
Crosstalk is excellent:
Specs are met with respect to power:
Full power is more or less maintained for the full audio range:
We can see the same in our sweeps vs frequency where 20 Hz output is not impacted:
The amplifier impressively doubles down in power up to 20 Hz including with reactive loads:
Noise on power off may be audible on sensitive speakers:
Amplifier is stable on after a few minutes:
It is clear that the Amplitude 16 is competently designed despite including 16 channels of power -- more than I have seen before. This takes away massive amount of clutter in a high-channel ATMOS home theater setup. We give up a small notch in performance from 8m but that is a trade off that I happily accept in not having to have two boxes.
On the cost, please note that this product is sold through the installer channel which requires healthy margins. So please don't compare it to companies selling direct.
I am going to recommend the Trinnov Amplitude 16 amplifier.
You can also get up firing speakers that reflect off the ceiling to replace the ceiling speakers. not ideal but still works.I have asbestos in the ceiling, I think Atmos is out for me
I am one too. High channel count theater with dedicated rack room with rack to the ceiling. I can fit a 2U unit and then the rack is fullI am one. Planned for 7.1 system and now facing having to have more channels for ATMOS. My rack is waist high and is already pretty full.
Not sure that's possible with Amir's testing gear. Or perhaps just impractical.I noticed there was distortion measurements with only 2 channels driven. I realise that is an industry norm. But for such a pricey unit, one would expect distortion figures with ALL channels driven.
That's not cost cutting (although the single DB25 probably is cheaper than 16 individual XLRs). Where do you imagine they would fit all the XLR jacks on the back of that thing? They'd have to make the box significantly larger just to fit them comfortably. Nevermind that custom installers, who are almost certainly their primary market, probably greatly prefer having one cable to connect to the back rather than 16 individual ones. Likely greatly simplifies cable management as well.Also, what's with the cost cutting of not having XLR & RCA inputs on the back of the unit? Instead you have to use some 16 cable adapter....
