I tried using 2D and 3D Spatialization and I don’t see a way to control just how much you want it to move each speaker.
You can choose 2 or 3D and Front and/or Surround. But if I pick Front and 3D, then it appears to try to bring the center all the way down to the height of the TADs, so it turns off the center completely and uses the L and R TADs as a virtual center …. Similarly it turns off my Surround speakers because they are too far back and it redirects those channels to the Top Middle Heights as those are just slightly in front of the Reference Listening Position.
Re Center and 3D remapping - in my prior iteration with ML Focus C I was getting the same - C was below the screen in my case - no, or almost no sound from it.
It was driving me nuts, until I realised, that all 5 reference MCH music tracks I have been using at that time did not use Center at all ;-).
One idea - you do not need to have reference measurement position exactly where your head is at MLP. If you look at my setup - SL is couple of cm too forward, so I get smth like 88dg angle if I measure it in reclined position. What I do is to take Ref measurement approx. 30cm closer to front speakers [basically where my knees are], but making sure that angles stay the same for L-C-R and then do my "cube of measurements" where my head is. I assign low weight to Ref and let Trinnov correct for MLP cube. You can try and place Ref measurement higher above your MLP to get elevation angles taken by trinnov less wild and attempts less 3D correction.
Also check your angles and distances in Positions/Summary tab [no idea how it looks in CI UI] 3D remapping is taking those as base for its calculation. If you intend to use 3D remapping, then Ref measurement is critical one, to get angles and distances right.
Does the Trinnov's 3D remapping help or have any effect?
Good question ;-) . Bit of my experience with "immersive bubble" . As you can see, I have slightly asymmetrical room, but in lot of aspects it is not the most challenging room. Firstly - "quantity has its own quality" in terms of speaker count, everything gets easier if you have more speakers to get spatial resolution and angles and having at least 9.x.4 helps a lot.
I will try to break it down:
L-C-R -
my current C is optimized for floor placement and I have screen placed quite low [as it should be ;-) ] so I do not have any screen side issue in terms of spatial coverage and soundstage. Also line source nature of ML's L-R helps a lot. But I still tinker.
DTS/5.1 - I use
heavily adjusted Auromatic for 5.1/DTS and I make use of Center Height + Front Heights in order to get "panoramic view" into soundstage without it bieng cut at tweeter level as usual with point source 5.1 systems. Wavedorming/DBA adds "directionality" and spatial cohesion [this is one of those things, that are hard to show on charts, but are easily audible]. So no need for 3D remapping
Atmos - I experimented with Dual Center setup [using Center H as second C] - it works great, but is limited to MLP, especially in height plane. Adds bit of a depth, If I would go for really big TV, this would be my go to option. But you need ability to steer both speakers independently to get it right. No 3D remapping either.
Surrounds and Mid/Rear Heights
DTS/5.1/Stereo - I use Trinnov's speaker array functionality and surround decorrelation to get immersive soundstage - in my case FW get assigned as LS/RS and then calibrated to get similar affect as in commercial theatres. I alternatively do the same for SH, sometimes I assign Mid Heights as Voice of God [not big difference between those two] .This makes real difference and also takes 2CH upmix to another level,
I routinely play 2CH music to "golden ears" with my upmix setup - and they never realize, that they are not listening to stereo, I get "great soundstage, depth" and "clarity" comments
so no need or use for 3D remapping either.
www.audiosciencereview.com
@PGAMiami - as you can see, I have subs placed between L-R, with WF engaged and 80Hz Xover there was a bit of unnatural "pin point" bass, coming as mono from the front. I found out that going down to 60Hz for L-R was the sweet spot in terms of natural spatial immersion.
