Trinnov AltitudeCI Review and 32 Channel Build Thread
Thank you for your offer to help. My priority is 2 channel music when it comes to sound optimization, so I don’t need much output below 20 hz. I learned the hard way that acoustics treatments and bigger speakers and amps will not help with your room bass problems. Placement of the TADs is very different than your ML. Mine are where they image best and where the SBIR is minimized above 80 hz. I’m letting Waveforming deal with problems below 80hz. In my room the TADs work best closest to the front wall and corners. Without DSP they would boom there, but with DSP the bass below 100hz is great. My biggest problems are between 100 and 300 hz where the SBIR is a factor and Waveforming isn’t effective, and still the room treatments are working marginally. Above that the TADs are great, but they are a bit too hot sounding, so some DSP makes them much more natural sounding.
I’ve got IIR going up to 250hz with 1/12 octave resolution and 50 filters. FIR resolution is at 1/6 octave. 3 reflections as the room is well treated everywhere that’s possible and important. Waveforming is working as expected. Amplitude is very flat and uniform to 1.9 db across all the measurements. It’s effective lowering decay, but only up to 90hz. I understand that about the upper limit when all the subs are on the floor. The front subs are Perlisten R210. These have more than enough output above 20hz and low distortion, so they work well with the TADs. The TADs on their own are flat to 17hz in room, but unfortunately with Waveforming they are limited to 80hz. If I was doing this over, I’d get the TADs CR1 and Perlisten D212s. Rear subs are Rythmik F12SE. They have enough output to act as absorbers for the Perlisten and are low enough in distortion and group delay.
I ran 13 measurements for the Optimizer. MLP is getting a 25% weight, the rest is evenly split in the remaining 12 measurements that are essentially at a 12” radius to the MLP. I'm hoping by having multiple measurements I can avoid the problems with the tighter resolution for IIR and FIR. I have Excursion set at 5 db for the speakers and 15 db for the subs between 20 and 200 hz. Waveforming settings are default with Pressurization on at 20 hz.
I owned Magico Q5s between owning TAD M1s (that were recalled due to cabinet failures) and my current TAD R1s. I was very disappointed with how the Q5s sounded and more so with the service from Alon.
Andrew Jones has been away from TAD for a decade or more, and I don't think much progress since he left. That said, the beryllium coax that operates from 250-20khz is still amazing, ultra low distortion, very well controlled dispersion. Imagining is very precise and if you're centered, it's extremely hard to tell whether you're listening to stereo on material with LCR content. My center is a KEF Reference 2C. Closest center speaker I could find to a TAD these days. With DSP the LCR sounds very coherent.
The two speakers I would consider as replacements would be the higher end KEFs or the Perlisten. Magico is not only buy list.
Optimizing the CI has been a slow but fun process. Trinnov really should get the manual done, btw. That said, it's probably the most consequential component I've owned in this 50 year quest for audio perfection.
Thanks for posting the measurements. I was comparing your 20 Hz result to mine and noticed some differences.
At 20 Hz you're showing about 80.6 dB SPL, while my measurement was about 96.5 dB, so mine was roughly 16 dB higher in level. From the harmonics you have displayed, I get roughly ~1.5% THD at 20 Hz, (min estimate since the 5th harmonic isn't shown). Mine measured 0.696% H2-H9 at 20.01 Hz, which is really surprising as it's also at 16dB higher (I use a calibrated source, so I know my SPL is accurate).
The 3rd harmonic also stood out. Yours is about 1.27%, while mine was about 0.265%.
However, I’m not sure how directly comparable the THD numbers are when WaveForming is involved. WaveForming changes how the bass field is created and cancelled in the room, so the fundamental and the individual harmonics may not combine the same way at the measurement position.
The emitter subs are also doing more of the actual output work than in a conventional arrangement where all subs are simply contributing constructively, which probably explains the slightly higher values (of course they are still really good as most setups are 10-20% THD down there :) ).
Measurement distance from the absorber array could matter too. If the mic is relatively close to the active cancellation region (usually about 1 meter per Trinnov), the fundamental could be reduced differently from the harmonics. Since THD is calculated relative to the fundamental, that could affect the percentage quite a bit.
Either way, thanks for sharing the measurements. They're very useful to see, especially from a WaveForming system.
This is also my approach - get best speakers you can, place them properly, do acoustic treatements you can live with and only then deploy DRC for Bass and final touches. You will not EQ out shi...y speakers or glass aquarium. And of course - get as many subs as you can squeeze into room, only overkill cuts it for me;-).
BTW - out of my experience - I have speakers [electrostats] that are quite demanding re proper placement [dipoles with quite specific off-axis] and I think I am quite good at placing them properly. But optimal placement for Trinnov DRC is slightly different to "analogue" position - as I do not need to focus on bass area and I can prioritize mids/treble.
I have focused lately on "no distortion/compression" aspect and linearity of acoustics, and this was a step forward. I do not need to employ filters above 2kHz for L-R and overall I use filters much less. WF does most of the heavy lifting.
This is my T20/T30 after latest acoustics re-shuffle and it was bigger change than swapping amps some time ago.
Also overkill on woofage - 8x18inx2500W each yields very low distortion. You can see exactly where Pressurization kicks in and it goes from 0.5% to 1% in infrasonic. FWIW - I am big infrabass fan so I also ask myself "how loud can I get this 8Hz earthquake playing ;-).
I am not on board with "10% distortion is good enough for bass" type of installs and I also put big focus on Group Delay, as this is one thing you can defintily hear if is rigjht or wrong. Here WF is doing great job [and I help it by not having any Bass Reflex speakers/subs]
i need to redo my REW measurements. I had set the excursion limits for the subs way up after seeing a video that recommended that. Then as i dug deeper into the Trinnov graphs I saw that the filters were trying to even out a room mode at 120 hz by throwing 15db of gain at it ... No bueno. Now I'm using more conservative excursion curves, but along with that I have to set the Waveforming Decay on low and the Waveforming Limiter on max. Otherwise it goes a bit nuts with the 120hz null, even though I have LR 24 db LPF 80hz on the subs. The other thing i did was take 5 additional measurements near the main listening position. That really helped with keeping the algo from overcorrecting things, really everywhere. Also played a bit with the target curve and the excursion curves. The TAD R1s have excellent in room response above 1500hz, so the excursion there is now just 0.5 db for the TADs, and the modified target curve for everything is now a Harmon curve with 4.5 db of bass boost and one that smoothes things up tp 1500hz, and then follows the TADs. So the KEFs and TADs sound essentially the same. And I keep EQ on the TADs at a minimum. I know how much work Andrew put into these in anechoic chambers, etc. So why not match to that. Sounds very good. I only have 4 10" subs now because the rear subs are just absorbers down to 18 hz. So I surely have less output down low, but more than enough for music.
So how many subs do you have? Are you crossing to main speakers at 120Hz? If you have 8 decent subs, I wouldn't accept a room mode just to use WaveForming... It's a bit of a gimmick if you're leaving a massive room mode by not running all subs conventionally. You can usually have +/-1 dB performance with 8 subs if you set them up properly.
All I care about is the acoustic summation of all my subs as I always run them together. Trinnov honestly doesn't handle multiple subs very well in conventional mode, but can be forced to do it correctly through manual means: https://www.audiosciencereview.com/...nd-32-channel-build-thread.71992/post-2677296
I have 2 Perlisten R210s in front (4 10" drivers total) as emitters. 2 Rythlik F12SE in the rear (2 12" drivers total) as absorbers. The crossovers are all at 80hz except for the 2 height speakers. I guess if you were counting speakers that could easily produce 20hz and below, the TAD R1s are down 3 db at 17hz in room, at very low distortion. Waveforming is working well up to 80-90 hz, as predicted by the physics. The problems are above 120hz.
Problem with me buying 8 subs is my wife will divorce me and take 4, so I’m back to square one.
Seems a bit heavy handed to say Waveforming is a bit of a gimmick. In my room with 4 subs it works great up to 80 or 90 hz, and my LPF/HPF are set at 80hz 24 db LR. The room modes below 80hz are pretty much gone. I'm not a fan of crossing over at 120hz as I rather use my TADs as full range as possible. They are fine generating clean output down to 17hz in room, but the room problems make using just two TADs full range very suboptimal below 80 hz.
With some help from Claude I was able to fix the bass from 80 up. I was having an SBIR issue mostly with my right TAD between 120 and 140hz. Claude helped diagnose this, recalculated optimal positions for the TADs and sofa (within my aesthetic requirements) and this solved the problem. The remaining amplitude errors were mostly minimum phase and the Trinnov IIR filters are doing a great job now getting the bass to be right at my target curve for the left speaker and within a couple db for a narrow dip for the right. Net result on music (especially with mono bass below 120hz) should be inaudible.
If I had your equipment, time and expertise, it would be very interesting to see how one could use the TADs all the way down to 17hz and treat them just as two more subs. That plus my other 4 subs in just the right places, with just the right delays and filters may be a great solution. Dirac ART sort of did this, but I didn't like the black box nature of ART.
BTW, I'm amazed at what Claude can do if you upload screenshots of the Trinnov amplitude, direct amplitude, filter and phase graphs. Even more so if you tell it more about your equipment, room, wall construction, acoustic treatment, possible speaker, sub and seating positions ...
After I got the amplitude response as good as I could (mind you, this is per Trinnov calculations which I know is not perfect), I still found many of my favorite recordings didn't sound quite right. So I sent Claude a screenshot of my target curve that was very close to the Trinnnov Strong curve (with a bit less bass boost and an extreme treble that rolls off closer to the TAD natural roll off). Claude came back with some adjustments to the target curve, most tenths of dbs, to adjust the slope of the bass shelf and treble tilt, while respecting the TAD roll off at extreme top end. This was probably the most important adjustment, second only to getting the SBIR problem solved.
If you heard my 8 subs that are conventionally setup, I'm pretty sure you'd agree it is better than most WaveForming setups. Sure, not going to beat WF installs with more than 8 subs, and I think a full WF setup in a large room is not a gimmick at all. But for me, I'd be in the cancellation region due to room space, so yeah, it's not for all situations.
If you are fine with your front subs working harder, it may work perfect for you. If they have the headroom and can handle it without adding more than a small amount of distortion that is. No way to know with a USB mic and REW as you need accurate THD measurements to see.
Your original post sounded like you still had a room mode for the LFE channel. Honestly, if that were the case, it would be a bit of a gimmick in your situation as that's the core function of WF. Obviously, I know that's not the case now after you added a lot more detail, you meant your main speakers had a room mode above the BM crossover region.
I'd still argue that crossing higher may be worthwhile, but no higher than 110Hz or so... Depends on your subs, and you need accurate measurements (especially THD and waterfall or spectrogram) to know which is best.
Yes, each room has its own set of problems and of course we are rarely starting at zero with our existing equipment. My TADs were simply in the wrong place. Once I moved them the problem at 120-140hz was greatly diminished. Maybe it's more of an emotional than an engineering question, but it would pain me to crossover the R1s at 110 or 120 hz. For my room, my equipment, the music i listen to, the low priority i place on the atomic bomb explosion in oppenheimer ... I'm happy.
The Perlisten subs are very clean on distortion. It's a clever design with the down firing driver inverted in how it's mounted and inverted electrically so it's acoustically in phase while canceling some of the distortion of the other driver. With a miniDSP mic and REW, they don't measure different than the TADs on distortion.
The TADs i have are twenty years old. DSP was at its infancy 20 years ago and it was very hard to integrate subs with speakers. I tried for years, with Quads and Entec subs. Levinson crossovers. Custom crossovers. Everything you can imagine. And settled on getting TADs that didn't need subs. But that does not address room modes at all as you well know.
If I was doing this over, I would get the TAD CR1 that is much smaller, less expensive and are fine at 80hz. I'm a huge Andrew Jones fan. His beryllium coax is something else. It's 20 years old and still sounds great. Pioneer gave him an unlimited budget to make a great speaker and that was what came out The coax plays from 250hz on up. Only the TAD R1 and CR1 have that coax. The KEF Reference coax get very close now, maybe even better in some respects. I really value how these coax image. Before working at TAD, Andrew worked at KEF.
One interesting note for you, Andrew has a twin brother that is an EE. He was working at Benchmark and had a big hand on the design of the AHB2 from what Andrew tells me. That is how I ended up buying AHB2s.
Totally, nothing wrong with that. They're really nice speakers, plus they're yours... I will say, if you ever have a system that can do 90dB at 100Hz with .188% THD and 90dB at 80Hz .0.082% THD, where THD is acoustically measured at the MLP for all 11 speakers, you'll instantly hear how life-like bass can sound.
Stereo content benefits greatly from it too. Distortion in the upper-bass region is actually very easy to hear once you've heard it reproduced cleanly.
Of course, I'm not saying I could have done it in the 80's (especially since I was in grade school) or the 90's lol. The Trinnov was really close out the box, but not good enough when using a conventional sub setup:
I know I've already said this, but I wouldn't trust USB mics for measuring THD at frequencies that low. I'd also have serious doubts about their phase accuracy down there, especially if you're trying to make timing or alignment decisions from the measurements.
I'd look for some used Benchmark or RME gear and pair it with an Earthworks M30 or a similar measurement mic. That gives you a much better-known signal chain for both distortion and phase measurements.
Imagine optimizing a system with analogue crossovers, mostly 2nd order, with very few adjustments. Something like the Pass XVR1 had more controls to adjust Q and move the crossover frequency individually for each pole, but with dip switches. Needless to say, I gave up and bought speakers that could reproduce 20hz on their own.
With Claude “at my side”, the speaker, sub and seating placements were significantly improved simply using the information from the Trinnov graphs. I watched a movie last night for the first time since making these changes. I can’t believe how amazing the sound experience was, even with just a 5.4.2 system and the surrounds set too high and too far back. The speakers all disappeared and I kept looking behind me thinking someone had come into the room. Sound effects have never been this realistic and the LFE was also very impressive. The room sounded like a big theater for the first time. I suspect that much of the immersive improvement is from the Trinnov knowing where my speakers are, as opposed to a Dirac system that assumes they are ideally placed.
I’m not a big immersive music fan, especially on music that I’ve been listening for decades on two speakers. I have an Nvidia Shield and about 1T of immersive high def music that a friend gave me, that I can play with Kodi. Works fine sonically but the GUI is horrible compared to Apply TV. But I can also play compressed Dolby Atmos and lossless stereo with my Apple TV. I must say with the Trinnov Optimizer it’s very hard to distinguish when a well done Atmos is playing vs a lossless stereo track. The KEF Reference 2C blend flawlessly with the TADs. And on stereo tracks the TADs sound as if you have a center channel.
Most importantly, many thanks to etc6849 for referring me to your Trinnov dealer. Problem now is the movies sound so great that I’m looking to upsize my 83” to 98 or 100.
That's awesome. How many albums is that, and are they all lossless (MKA or MKV files)? I've played a few dozen atmos albums on the CI, and they sound incredible. Many I consider some of the best quality albums I've heard in years. So far, about 1/3 albums are decent, with the 2/3 being ok, just no better than 5.1, especially with the upmixing the CI can do.
Yes it’s all lossless. Mostly MKV, Dolby HD, some also in DTS, and also Quadio. Several hundred albums. Some is very good, but some sounds very gimmicky with random instruments playing behind me. Once you get used to something like Roon, Kodi on an Nvidia Shield feels like an old IBM 370 mainframe interface. Too bad all the immersive material on Apple Music is compressed because the Apple TV interface is much more polished. My Roon library is 19300 albums, 9T. No new material since 2016. It was put together by my former dealer. Some very special HD two channel material there that he collected over many years, including Japanese CDs and archive quality transcriptions of Beatles LPs done with Rockport turntables and Pacific Microsonics Model 2. But sometimes it’s just too much as there are a handful of versions of the same CD, redbook, remaster redbook, 96khz, 176khz … they all sound different and were done at different gain levels. Which one do you listen to? That’s what’s nice about Apple, they at least try to find the best master they can and use that. Even if it’s 48khz, getting the best master makes the biggest difference I think.
Interesting. I was surprised at those numbers but the second sentence explains the first to me. I have only about about 7000 albums but my library is about 30T! This suggeests that the balance of compressed vs. uncompressed source content is vastly different in our collections. Have you missed out on the now-fading flourish of wonderful, discrete, uncompressed multichannel files released since 2016?
Wow. You guys have some nice collections! I love multi-channel albums, but sadly only have 182 (648 GB). First world problems I know... I converted them all to FLAC, updated tagging, filenames, covers, etc...
I also have 163 atmos albums taking up 435 GB. All were converted to MKA files and tagged properly using MKVToolNix, including embedded covers. The MKA conversion removes video, which greatly reduces the size of the files.
@PGAMiami
I use JRiver to analyze all my FLAC files, then use the maximize volume for peak normalization option and the DSP option: peak level normalize. This ensures existing dynamic range stays intact, but the track levels are raised such that the sample peak for each track is .01dBFS below 0dBFS. If there are inter-sample overs (ISOs), I let the DAC3 B's downstream handle them.
This method preserves the valuable digital headroom at the AES outputs of the Trinnov (internally it uses 64 bit, so no issue internally), as you no longer have to turn the volume up 6dB or even up to 20dB to account for lazy mastering :D. I think Roon can do some of this, but JRiver is much more versatile (and much cheaper). I like using sample peaks as the Trinnov keeps the sample rate output consistent with that of the input, and again any ISOs are handled by the 16 DAC3 B's.
PS: I took a quick look at Roon:
Roon can do some of this, but it is not doing the same thing. Its Volume Leveling is based on loudness normalization, so it is trying to hit a target LUFS level rather than simply reclaiming all unused sample headroom. In other words, a track peaking at -10 or -20 dBFS would not necessarily get raised close to 0dBFS unless that also happened to be the gain needed for Roon’s loudness target. There also appears to be a DSP option to lower or increase all tracks by a given amount. This doesn't seem very well thought out to be honest.
In my system, I prefer JRiver’s approach because it leaves the existing dynamic range alone and simply uses the available sample headroom. This is much more elegant from an audio engineering standpoint.
The immersive music is maybe a couple years old or a bit more. It’s relatively recent.
Yes I only recently started optimizing for multichannel. My speakers don’t match and are not in ideal locations.
The center is a KEF Reference 2C. It’s about as close a match as I could find to my L and R TAD R1, other than a prohibitively expensive TAD CR1. It’s above my TV so the position is not ideal. I have an adult son with special needs and he will damage them if he can reach them.
For Surround I have KEF R3 Meta, also wall mounted high on back wall. Top middle are KEF R8 Meta.
So this is not an ideal speaker array. The Trinnov sounds better than a Denon receiver. My target curve is identical on all speakers. That helps a lot and they all use coax drivers, which i think also helps.
On movies the system is great but I think the less than ideal speaker locations are hurting the immersive music experience.
I think the biggest problem is the center being so high and surround being high and too far back.
Does the Trinnov's 3D remapping help or have any effect?
I haven’t tried using it. From my understanding of how it works I’m suspect whether it could help much in my case,especially with the surround channels that are too high up. It would need nearby speakers that are lower and I don’t have any nearby.
I think in my particular case what could work is using smaller KEF R8 Meta and installing them in the correct locations with a protective covers. Bandwidth would be more restricted vs the R3 Meta. but overall from a spatial perspective I think it would work better.
This is exactly how I’m optimizing my system today using JL audio CR-1 active crossover (analog) with Revel Salon2 that goes down to 23 Hz and a pair of JL Gothams. I use low pass crossover of 105 Hz so the subs get more of the action and the high pass at 55 Hz that relieves the Salon2 from deep bass and also sealed the salons to reduce group delay. This removes a nasty dip between 60-70Hz in my room. I think it sounds outstanding for 2 channel music and I’m 100% happy with the non-fatiguing sound and seemingly unlimited bass.
Having said that, I plan getting the Trinnov CI not only for movies but also for multichannel music or even 2 channel music. Since I got my 83” not too long ago, I’m stuck with it for a while.
