How do you connect the Altitude CI outputs to these DAC without AES input?The rest of my faceplates came in... Kinda sucks I have to make 36 more cables. I have some serious first world problems.
Although certainly not very scientific, there is something emotionally appealing about having a 100% Benchmark signal chain post the Trinnov DSP and decoding.![]()
Canare BCJ-XJ-TRC Transformer - XLRFM to BNC - 110-Ohm to 75-Ohm - For
This transformer can be used to adapt balanced AES XLR digital sources to the coaxial inputs on all Benchmark converters.benchmarkmedia.com
And yep, I went all in on this, no turning back now:
Most studio dacs with AES inputs do not exhibit any intrinsic fading effects. None of my RME or Motu devices fade-in. How many analog out channels do you require? Perhaps the Okto 2 or 8 channel DACs might be worth investigating.Has anyone experienced problems with calibration measurements on the CI resulting from fade-in features that are programmed into DACs as they transition from digital silence to a music or test signal? I’ve been seeing in the SMLS SU-2 thread that it has a 1/60th second fade- in when coming out of a digital silence that lasts more that about .3 seconds. I would think that plays havoc with Trinnov calibration unless Trinnov sends a dithered or pink noise preamble immediately prior to each measurement.
Any experience you all have on this is much appreciated, including suggestions on DACs that have AES in and XLR out that would not have this problem. From the research I’ve done, many consumers DACs will have this problem and some will mute when one channel is silent, etc, with notable exceptions from Schiit, Benchmark and RME.
4 channels. Okto 8 would work. Supposedly Schiit Mimir.Most studio dacs with AES inputs do not exhibit any intrinsic fading effects. None of my RME or Motu devices fade-in. How many analog out channels do you require? Perhaps the Okto 2 or 8 channel DACs might be worth investigating.
I am using the CI's own DACs for most channels but sending LS/RS via AES3 to KEF LS60s. No anomalies with the calibrations.Has anyone experienced problems with calibration measurements on the CI resulting from fade-in features that are programmed into DACs as they transition from digital silence to a music or test signal?
Not sure I follow WRT Trinnov specifically. Trinnov devices originate the calibration signals, so you wouldn’t be sending anything through an external DAC, only either the one in the Trinnov itself, or if you’re outputting to Dante through a Dante DAC. I guess you could go through an external DAC from a Trinnov device, but as good as the Trinnov DAC is purported to be, why would you?Yes, from my research almost all studio AES gear should be fine. I would think most speakers with AES inputs should also work as evidenced by Kal’s set up. There is very little documentation on how consumer DACs deal with digital silence, but the more I read, the more I see inconsistency that can cause serious problems. There are reports that some DACs will mute both channels if one is silent. Very problematic if you’re measuring channels separately. Certainly the SMSL looks very problematic with a 1/60th second fade in following digital silence of more than .3 seconds.
I would think a simple impulse response test would quickly show whether there is a problem. But I don’t see many of these, not even in Amir’s tests. I went back and read Stereophile’s review of the Okto DAC that Kal wrote. That impulse response looked fine.
And since this Auto Mute on Digital Silence is now a default option on many popular DAC chips, I can see how this has become common on the DACs. I would think a 1/60th second fade in is very hard to hear, but I can imagine it could cause big problems for Trinnov if it’s not expecting it as it will think it’s part of the speaker/room response and distance.
Altitude CI only has 8 channels of analogue out It’s much cheaper than Altitude 16. Can be expanded to more channels with its 16 channels of AES (8 AES3) or Dante.Not sure I follow WRT Trinnov specifically. Trinnov devices originate the calibration signals, so you wouldn’t be sending anything through an external DAC, only either the one in the Trinnov itself, or if you’re outputting to Dante through a Dante DAC. I guess you could go through an external DAC from a Trinnov device, but as good as the Trinnov DAC is purported to be, why would you?
Turn on Waveforming. Even if your subs aren’t in perfect spots, it’s a game changer. My favorite demo is Andor Season 2, first episode once Andor steals the experimental TIE Fighter. Even with Disney+ lossy streaming AC-4 Atmos, the bass of the blasters is incredible in both the intensity and ability to feel each blast of the high speed lasers *and* how tight the bass is, such that each blast is felt cleanly and they do not blur together at all.
TRINNOV ALTITUDECI
AES OUT DB25 #1
Doremi/DCI
channels 1–16
│ use channels 1–8
GENELEC 9301B
AES INPUT DB25 #1
channels 1–8
AES OUT DB25 #2
Doremi/DCI
channels 17–32
│ use channels 17–24
GENELEC 9301B
AES INPUT DB25 #2
channels 1–8
If I want to connect the AES output of the CI to 2x AES inputs (each 8 in, 8 out with outs unused) can I do it with 2 cables without splitting one? For example, use 8 channels of the AES 1-16 out and then another 8 channels of AES 17-32 out? Essentially I am just moving 8 output channels from the CI's 1st DB25 to its 2nd DB25
Code:TRINNOV ALTITUDECI AES OUT DB25 #1 Doremi/DCI channels 1–16 │ │ │ use channels 1–8 │ ▼ GENELEC 9301B AES INPUT DB25 #1 channels 1–8 AES OUT DB25 #2 Doremi/DCI channels 17–32 │ │ use channels 17–24 │ ▼ GENELEC 9301B AES INPUT DB25 #2 channels 1–8
Chatgpt seems to suggest it should be fine with the typical aes59 cables
