I can switch between formats in JRiver, but there is a 3-4 second delay on the Trinnov.
There is a very small faint tick I can barely hear sometimes when I play MKA files that are ripped from Atmos albums and switch formats. The Trinnov is designed to mute internally during these transitions of course (although it doesn't show it is muted on the display, it definitely is).
However, you can easily sort a JRiver playlist by audio format, that way there is nearly no delay at all between tracks (maybe 5-20ms not sure). No loud ticks/pops or anything like that.
Sounds all great, and sure an very good Device but absolutly out off my budget
First off all an main question about the crossover capabilitys?
Has it FIR Filtering and how long the max internal tap number is???
Can you Setup, let say 7x2 Way (7 x 2 Channels) and 2 Subwoofer (2 Channels) crossover to get 7.2 full aktive Surround Speaker Setup with it?
I use on my Setup 96dB LR Filter @ 96kHz and thats sounds so amazing i don't want to go back from this
At the end i use somthing Trinov do as well (Software DSP on an PC Base):
RME HDSPe AES on an PC Based system with an Intel Processor for now on Ubuntu Studio
That gives me 16 Channels and i can put in an second HDSPe Card for 32 Channels
Used on CamillaDSP Softwarebased DSP with plenty of Tap's and Processingpower for all kind's of Crossover stuff and i am free to use Hardware like i want.
DAC's , AMP's and so on.
I could also use an HDSPe AoX-D for Dante Out but i like to stik on AES, not sure how good the Linux support is on that. The AES Card works fine so far
I am do Speaker measuring now for more than 30 Years so i can make the Setup by my self with using REW , rephase and one Byerdynamic Mikrofone for 220€
without an fancy 3D mikrophone and Dirac.
REW is now capabel to make all PEQ for you automaticaly and convert it to CamillaDSP Filter Files with youre own Target curve.
Of course thats not for every one if he never designed an Speaker or has knowlage about Speaker Measuring and it kost you also much Time with all that Tools.
But it is also my Hobby since i am 15 Years old, now 56
My first Measuring Device was an external Sweep Device with Parallel or Serial input, sweeps all Frequences from 20 to 20000Hz and nothing more as an selfbuilding Kit runs on DOS LOOOL long Time ago. One Measuring need some Time, it was slow.
For an Endconsumer without much Knowlage about all this it's an realy nice opurtunity to get such an Device making all that for you (not used such a Device so not sure how easey it realy is).
But you need to pay a Price for that and stik with it how it is or what kind off updates are comming from Developer over Time.
For me i payed for now without Sepaker:
Softwarebased DSP with DAC's (2940€):
RME HDSPe AES 900€
TASCAM Based AES Cable 140€
PC around 1000€ (used parts i had already liying around, Processor, RAM and PSU)
8x SMSL SU-2 DAC 900€ (3 of them i bought for first tests so far, measured Syncronisation or posible Drifting and so on, works fine so far)
HYPEX Amps (2939€):
7x NC122mp 240€
https://www.soundimports.eu/de/nc12...eHcgsUiFLjp3w2Xf8saCQjtopfnCKSckaAqDhEALw_wcB
Alternative 399€ all inclusive:
https://www.audiophonics.fr/en/powe...tereo-ncore-nc122mp-2x125w-4-ohm-p-12756.html
2x NC250mp 214€
https://www.soundimports.eu/de/nc25...eHcgsUiFLjp3w2Xf8saCQjtopfnCKSckaAqDhEALw_wcB
Alternative 379€ all inclusive:
https://www.audiophonics.fr/en/powe...-mono-ncore-nc250mp-1x250w-4-ohm-p-14445.html
6x Evaluation Boards for first 2x3 Way Setup Test 58€
https://www.soundimports.eu/de/hype...eHcgsUiFLjp3w2Xf8saCQjtopfnCKSckaAqDhEALw_wcB
AMP enclosures (China) around 69€ for one Amp (CNC work by my own)
DIY HDMI to 4x AES Extractor (LPCM) around 200 - 300€ (work in Progress, Stereo works great already
Will be replaced in the Future with (for ATMOS Decoding):
ARVUS h2-4D 5k around or
Hyperion DPR-16 5k around or
Nuprime HX16-AES 3k to 5k nort sure for now, is on developement.
