- Thread Starter
- #21
When you define a source (e.g. "HTPC") in the CI, you have to pick a single audio protocol/audio connection type for the inputs and a single type for the outputs.
I don't think you can have Dante inputs and AES inputs active at the same time. You can have AES and HDMI active at the same time, where HDMI will just pass video, while you use the AES inputs, but even then you can't use HDMI for audio in and AES for audio in at the same time.
My guess is the AES loopback is doing nothing if you defined your selected source to use Dante. I don't use Dante, but would consider looking at their virtual driver to see if it can do loopback function?
If that doesn't work, you can try splitting it up the test if you have an AES in/out card in your PC:
CI AES in and CI Dante out
CI Dante out and AES in
PS: regarding the 16-channel Tascam cable comment... For others installing the CI in your theater and planning to use AES, you want a cable like this for the AES DB25 output:
https://www.bhphotovideo.com/c/prod...6_00_DB25_XLRM_DigiSnake_Analog.html/overview
And one like this for the AES DB25 input:
https://www.bhphotovideo.com/c/product/769733-REG/Avid_9940_30427_00_DB25_XLRF_DigiSnake_Analog.html
These aren't the TASCAM standard as they don't have 8 channels in/8 channels out. Technically this is considered the "Doremi/DCI Digital Pinout" as Trinnov points out here: https://kb.trinnov.com/en/knowledge-base/db25-pinouts-for-trinnov-products
Just bringing this up in case anyone ever wants to use the AES inputs or outputs... I know for sure the DB25 AES cables I linked to work, as that's what I bought and use in my theater. I know many have called these TASCAM cables before, including myself
I'm attempting to test a newly-received Altitude CI (16 licensed channels) which is connected via Dante Virtual Soundcard (DVS) to a Macbook Air M5 running REW. I've mapped M5 DVS outputs 1-16 to CI inputs 1-16 and mapped M5 DVS inputs 1-16 to the CI outputs 1-16 using Dante Controller. A 16-channel Tascam digital cable loops the CI AES output 1-16 DB25 into the CI AES input 1-16 DB25. The CI source is set to Dante.
When REW generates a 1 kHz tone on channels 1&2, corresponding signals are visible on the CI input and output meters. But, the REW spectrum analyzer detects no input signal from the CI. Web searches confirm that the 16 AES inputs on the CI are supported.
Any guidance or suggestions would be appreciated.
