Trinnov AltitudeCI (aka Altitude CI) Initial Review
etc6849
Columbia, SC
Background:
I did some quick digital-path testing on my AltitudeCI because I wanted to check the part of the unit that I use in playback: HDMI input to AES output. I am not using the AltitudeCI analog outputs, so I was not trying to test the DAC section or analog performance. I also don't feel like trying to sweep them as there's not a lot of space behind my front rack...
The test was inspired by the earlier Altitude32 ASR review, but this is not a direct duplicate of that test setup as I ran into REW limitations and didn't want to spend a lot of time, once I saw the outstanding results I was getting with room correction and a "Strong" target curve enabled, versus without.
The good news for the few tests I did, I do not see any obvious clipping, side bands, or strange HDMI behavior visible at the AES outputs that is of relevance.
Signal Path for Test:
JRiver Media Center playing playing wave test files → NVIDIA RTX 2080 Ti HDMI output → Trinnov AltitudeCI HDMI input → AltitudeCI AES output → RME HDSPe AES input → REW RTA capture
The RME HDSPe AES is best accessed through ASIO, while the Trinnov HDMI output from the PC is exposed through the normal Windows/Java device path in REW. REW’s driver mode is global, so I could not simply select Java for HDMI output and ASIO for RME input in the same REW instance. The workaround was to generate 96 k/24-bit -3dBFS WAV test files, play them in JRiver through my normal Trinnov HDMI zone, and capture the AltitudeCI AES output with the RME/REW analyzer path.
I used -3 dBFS test files for the main flat/no-correction checks. Captured levels matched the file levels, so the HDMI-to-AES path appeared to be at unity (for the flat measurements with room optimization turned off anyways).
I would not interpret the small far-out spurs as audible or practically significant.They are on the order of -175 to -180 dBFS, and the 2M FFT setting is intentionally revealing. A lower FFT length would likely hide them. They also appeared at 19kHz even if I perform a loop back test on the RME sound card by itself in REW, with the Trinnov totally removed from the signal chain. Unfortunately, I can't measure any better to remove them, as I have already turned on dithering which helped get rid of some... However, this is plenty good enough for me, and I can't swing Audio Precision gear plus have the Trinnov AltitudeCI :)
Bottom line:
In my setup, the AltitudeCI HDMI-in to AES-out path looks extremely clean at 96 kHz, even with my usual strong target curve listening preset plus optimization enabled... The very low spurs I have are reproducible, but are from my RME HDSPe AES card (as I did loopback measurements to prove this). I'm really happy to finally find a processor that does what I want, and to have decent HDMI that doesn't degrade audio quality (my last processor was in 2016).
The CI is highly recommended, but is not cheap at all. However, I figured, heck the room has 16 Benchmark AHB2 amps, so why not add a Trinnov processor too. There are actually very few options that could provide 32 AES input and output channels btw, with no down-sampling either (only tested up to 192kHz, and can't test beyond that). Of course, most movies are still mastered in 48kHz, but it's great to have an Atmos/DTS-X decoder that can work with my pro-audio based setup so well!
I will say that before when I tried room correction software, I quickly removed it as I found it to add slight artifacts. Not the case with the Trinnov, all I hear is improvement. It is one of the first processors I've had that didn't try to set my subs to some ridiculous value like 30 feet either.
In fact, the CI left most of my custom settings I had previously put into each Xilica XD4080, using an Earthworks M30 mic, Benchmark ADC1 and MPA1. And the 3d microphone is highly sensitive. Even if you rotate it as small as humanly possible, the slight rotation still shows up on the polar plot inside the CI's GUI that can map your speaker locations three dimensionally. It's that sensitive, and if anything, all the level and time delay it did improved from what I had meticulously done by hand.
The AtitudeCI I'm using is actually only 10 channels for now, and eventually if I can ever afford the channel upgrades necessary, I'd like to drive the remaining two height speakers, tri-amp the main bed and hook the subs individually to the Trinnov AltitudeCI. Right now, I'm still using 6 Xilica XD4080 Speaker Processors (4in, 8out) that are fed AES3. They act as the DSP for crossing to the 8 subs, tri-amping the 5 bed channels with FIR filters, all time alignment, all level alignment, etc...
Hopefully I can one-day remove the excellent Xilica XD4080's and add more Benchmark DAC3 B's connected directly to the Trinnov Altitude CI. This would actually be a lot better for headroom management, plus the DAC3 B analog outputs provide a few additional dB of headroom over the XD4080 analog outputs. I've been slowly adding the DAC3 B's as I find them used, since the Xilica XD4080's have digital inputs and outputs as well.
Flat results with no correction:
-180dBFS WAV File Test (Flat target curve, no optimization turned on):
-3dBFS WAV File Tests (Flat target curve, no optimization turned on):
Strong Target Curve Plus Room Optimization:
Notes for these tests with the "Strong" target curve and room optimization turned on: I had to set the Altitude's volume down -8dB just to prevent any clipping due to the room optimization adding a few dBs, plus the fact that the target curve is a little aggressive:
That's why I labeled these measurements as -11dBFS, while they are the same -3dBFS WAV files as before...
Some pics of the setup:
Thanks! I didn't put this in the OP, but I even handmade 100+ cables to connect everything. I used Canare star-quad cables for the XLR, AES and even the trigger wires.
Here's an older picture of one of the racks before the Trinnov and the custom water-cooled PC:
".... has 16 Benchmark AHB2 amps"!! Just really amazing... :D
Incase if you would be interested, you are cordially invited joining participating on my hosting thread entitled "Let's share diagrams (and photos) of our total physical audio system and the whole signal path, with a few words and/or links".
Wow, not only your hardware setting/configuration but also the most careful and skillful wiring tidying-up efforts are also just amazing!
At least I myself really like seeing such a backside wiring photo/view...
It looks you are using very quiet Noctua fans in your DIY/custom water-cooled PC, right?
Definitely. I did each rack that way. I'm sure there are professional integrators who do that level of work too, but I probably couldn't afford to pay them plus have all that gear in there! Three of the subs I bought broken and repaired too, and most gear in that room is used with a few exceptions.
With minimal/optimal length cables; just beautiful and really nice!
IMHO those tiny (< -160dB) peaks could easily be artefacts of the HDMI/AES 24-bit path or REW float32 processing of otherwise bitperfect chain (digital -> digital). I would recommend to ask REW author @JohnPM .
Looks to me like the WAV file and generator output were not dithered, should turn on 24-bit dither.
HDPSe AES loop back looks even better now. Thanks John! EDIT: oops, turns out even with 24 bit dither on, there are still small spurs, especially on the 19kHz test...
Eventually I want to try it, but I have 8 subs and only 10 channels unlocked on the CI, plus Trinnov raised the price of the licenses a week ago, which also sucks.
Are you using, or planning to use Waveforming?
If you are ever in the US, stop by for a listen. The Trinnov AltitudeCI really brought my system up that last few percent, and is some fantastic engineering.
You room is, in a good way, absolutely bonkers.
Yep. You can just faintly hear the PC when the graphics card is at full power. I still use the Nvidia 2080 Ti for MadVR, and it does an outstanding job. If I ever get into gaming, I have plenty of thermal headroom and will probably upgrade the card, but space is a little tight!
Around ~10% increase across the board. However, now they include tariffs into the price, so it wasn't really a 10% increase for physical products... The CI is still one of the cheaper options if you need more than 16 channels (or might in the future like me) and want the absolute best performance. I prefer having digital outputs too; it integrated perfectly into my existing pro-audio setup, and the freedom to add the additional 20 channels as I have the funds is neat too.
How much was before and how much is it today?
I don’t remember paying a tariff on mine when I added channels…
Also don’t get me started on tariffs, may no longer be welcome on the forum.
There's no tariff on the software licenses... No idea why they hiked licenses ~10% when the CI hasn't been out for a year and came with so many little bugs... The latest firmware is better, but I still have bugs such as the GUI not showing the correct video refresh rate when I start a movie in JRiver. This is pretty minor as everything works great, but for five figures, I expect flawless performance.
Frankly being told software licenses were $X, then having that price raised after I paid in advance for the CI and waited 3 months for it (after being promised delivery dates and having them pushed out multiple times) seems unnecessary. It honestly comes across as a money grab, so now we're going to raise prices on you for the upgrades you were planning while you beta test a five figure processor you bought...?!?
This is from the latest firmware release notes, and lists some of the bugs, but not all of them. More transparency is needed here, because I don't want to waste my time emailing Trinnov support about issues they already know about. I have no doubt in a year or two it will be without bugs. This last firmware update was a step in the right direction in my experience.
"AltitudeCI 2.1.2
Do not turn off the device during the update process!The unit will automatically restart twice, so wait for the UI to be fully functional before switching it off.
New features
• 192 kHz support expanded to 32 channels.
• Support of 512-byte EDID for HDMI.
• Graphs are now directly accessible in the Calibration Wizard after calibration and compute.
• New option available to mute DACs with relays : may reduce or suppress issues if you are experiencing audio glitches when switching content.
• New option available to automatically boot on power-on (for instance, can be useful to automatically resume operations after a power outage).
Enhancements
• HDMI firmware is now updated along with the system update.
• Remapping setting is now saved into the preset.
• Front panel backlight turns off when the ‘Screen Saver logo’ option is disabled.
• Performing a factory reset will now display a spinner until the unit automatically reboots itself.
Bug fixes
• Fixed RS232 automation. The serial baud rate for AltitudeCI must be set to 115200.
• Resolved remaining network standby issues when turning off the machine.
• Fixed some situations where random freezes occured.
• Resolved a bug causing no audio when using Dolby Center Spread without an upmixer.
• Addressed several clocking issues.
• Fixed a bug where audio routing was incorrect after switching HDMI content, which lead to a loss of the center channel or audio limited to L/R.
• Fixed autosave issues.
• Resolved a bug with Xovers calibration offset, where L-high volume could not be modified.
• Fixed a bug with AES Inputs, where sound was still visible in volume meters of unused channels.
Known limitations & bugs
• Roon and UPnP inputs are not supported yet.
• La Remote is not functional.
• Save process can sometimes take a long time with a spinner displayed on the interface.
• OSD is currently not available.
• Upmixing native Dolby content with Neural:X or Auro3D may result in playback issues or complete loss of audio.
• When applying a 'Function' to a source (e.g., 'Input Routing'), the setting does not take effect immediately. You must reload the Source to apply the changes.
• If the image fails to display after waking the device, go to SOURCES/HDMI and press 'Refresh' EDID."
I'm attempting to test a newly-received Altitude CI (16 licensed channels) which is connected via Dante Virtual Soundcard (DVS) to a Macbook Air M5 running REW. I've mapped M5 DVS outputs 1-16 to CI inputs 1-16 and mapped M5 DVS inputs 1-16 to the CI outputs 1-16 using Dante Controller. A 16-channel Tascam digital cable loops the CI AES output 1-16 DB25 into the CI AES input 1-16 DB25. The CI source is set to Dante.
When REW generates a 1 kHz tone on channels 1&2, corresponding signals are visible on the CI input and output meters. But, the REW spectrum analyzer detects no input signal from the CI. Web searches confirm that the 16 AES inputs on the CI are supported.
Any guidance or suggestions would be appreciated.
I can’t help you other than suggesting to ask @fattire over at AVS. If you post in the CI forum I bet he will chime in.
