Finally (!) got my SDP-75 set up and running. The manual needs work but the unit is very impressive. John Schuermann helped and also pinged Harman to get the unit updated for me. I need to set up some time with John or a Harman calibrator to tweak the settings. I wish they would just publish the tweaks -- some of us can probably follow directions.
I have piddled with some of the advanced optimizer settings just for fun though the Wizard got pretty close. Which reminds me, the Wizard is way cool and walks you through the steps to set it up without needing to wade through the manual (though it helps), but it is mentioned no place in the manual! I was clicking on the icons in the GUI and found it.
I was somewhat disappointed to find it takes an on-site visit for them to set up SFM; I have enough channels so each sub (4) has its own so thought I could do it in the unit, but a factory calibrator has to be on site to enable and set up SFM. It's currently $5k USD for the visit and you can't schedule it even if you have the cash on hand (I don't) due to the COVID-19 lockdown.
At least they updated to 4.2.15.1 so I have the Harman anechoic data for my speakers and was able to set the Harman target curve. Kevin K (not KV, different Kevin) worked late last Friday to make that happen -- I didn't give the public IP address (analog guy, not a network guy), the it wasn't on his "master list" so he had to loop in engineering to do the update.
Edit: Per John, if you use Synthesis amps (with DSP), you can take measurements, Harman can crunch, and you can enter the settings into the amps. My amps are conventional analog so not an option. Or miniDSP or subs with DSP/PEQ. My subs have analog PEQ so might work but would be an iterative process without fine parameter control.
I made a few tweaks based on what I have read here and there, such as limiting correction to 250 Hz, and with and without letting it correct first reflections. I saved their default (Wizard) cal and a couple of tweaked versions. The position graph is pretty neat; mine were actually almost dead-on with respect to symmetry though my sides are rather forward (room limitations). I spent some time adjusting my speaker positions today just for grins, pulling the L/R a little forward and out a bit (they are about spot-on with the recommended positions now) and moving the surrounds a little forward (had to move some shelves) so they are about +/-60 degrees (about where I wanted them, best I can do in this room, and they were a little too forward before at +/-50 degrees). It sounds pretty good but I've almost no listening time so far.
Among things I wish it had were more trigger outputs (fortunately I had an Emotiva trigger expansion box and couple of Y cables), a front panel USB jack, and a universal shock mount or at least swivel mic adapter for the mic (it wouldn't work with my boom and I don't have a shock mount that will fit it -- ordered a cheap one from Amazon to try). And for minor nits, since they pulled the remapping section from the manual the book mark is missing in the ToC, and the page numbers after that are missing. The manual is an interesting mix of info, not a lot of detail in some places and leaves out some basic info (like to load the mic cal just plug in the USB stick), and the section order is "interesting" (maybe just not what I expected, a personal thing).
On the plus side there wasn't much written about video pass-through but it just worked for me. The cable box and Oppo are doing fine, and 4K HDR passed through no problem. And so far it has been very reliable in linking HDMI and so forth, a welcome change (though my XMC-1 has been doing OK since the last FW update).
Looking forward to dialing it in! - Don
