Maybe slight off topic (no idea about you channel status) - I used MSO/Flex with great results.Yes, after a DBA or Multi Sub the critical range is from the XO to your subs till Schroeder. In my setup it is like this. I have 4 subs optimzied by MSO. Very good response and seat to seat consistency to about 120Hz and till 200Hz still better than my fronts. XO is at 120Hz therefore. Active absorbing via MIMO till 200Hz would be very helpful here since I cannot stick so much passive absorbtion to solve the problems from 120-200Hz.
Now I get even better with combination of Trinnov 4 way cross over. I just measure each sub individually in REW, cut the first mode around 30Hz, use BM delay proposed by Trinnov - and get very good results for MLP.
sounds more defined than MSO. YMMV
