MacCali
- Joined
- Dec 21, 2020
- Messages
- 1,192
- Likes
- 586
Freedom FriesThanks, Amir.
Absolutely stunning look and performance for a multichannel amp !
Designed in France, but Made in USA... Quite unusual.![]()
Call me old fashioned but I'm jealous seeing the linear power supply with those big transformers.
Nothing like nice pair of large toroidsCall me old fashioned but I'm jealous seeing the linear power supply with those big transformers.
Made in USA means the Hypex modules are also made in USA as in order to be classed as Made in USA, the "product is "all or virtually all" domestically produced, manufactured and assembled in USA." I didn't know that Hypex modules were made in USA.Thanks, Amir.
NAD m28 as pointed above is about half the price and missing only one channel and I’m pretty sure it’s not far off the M23 with probably a fairly competent smps.finished nc1200 stereo power amps are like $1,500 right? and so you need four to get this thing...
ummm.... its not out of the bounds of reason but i question why you need to get 8 channels into one chassis and all the demands it has on one psu...
if this is going into a cabinet then just get a couple of stereo units and use 4 power cables???
Wonder what that is, maybe more power/larger modulesInteresting that it seems there are two versions of the amplifier. I found this on Google. Slightly different back-panel layout as well...
Case is also different,it's divided in two parts on the top,Amir's sample is just one piece.Interesting that it seems there are two versions of the amplifier. I found this on Google. Slightly different back-panel layout as well...
I added the page link where I copied the image and it seems both versions are the same, just different layouts.Wonder what that is, maybe more power/larger modules
Seems like it's made by ATI:I added the page link where I copied the image and it seems both versions are the same, just different layouts.
B-but... ATI is AMD for like 10+ years already
The link @sarumbear provided is from 2016.B-but... ATI is AMD for like 10+ years already
Montebello, CA , September 1, 2016 – Amplifier Technologies, Inc., the prolific manufacturer of many of the high end audio’s best amplifiers today added a new series of amplifiers. The ATI AT54x Nc amplifiers use Hypex N-Core Class D output modules with ATI designed input buffers and linear power supplies and are available with two power configurations. The ATI AT54x Nc amplifiers use two N-Core modules per channel in a differential bridged output configuration delivering 500W RMS per channel at 8 ohms and 900W RMS at 4 ohms. The ATI AT54x Nc amplifiers are available with 2, 3 or 4 channels.
Amplifier Technologies owns the ATI, Audioaccess, BGW and Theta Digital brands and designs and manufactures state-of-the-art audio components for its own and other brands in its facility in Montebello, CA. Guided by legendary amplifier designer Morris Kessler, ATI offers both performance and value in audio components.
Well, even if it's soldered to PCB in America, components are definitely made elsewhere. So where exactly is that borderline, assembling PCB equals "made in" but asslebling unit with pre-assembled PCBs/plate amp units is not?In which case how can they say Made in America?
Ok,I think I found out what's happening.![]()
ATI AT54x Ncore Series Power Amplifiers | Ideal AV Home Cinema
ATI AT54x Nc are the best amplifiers we have ever heardwww.idealav.co.uk
Not clear but it says it uses Hypex modules, which are manufactured in Malaysia. In which case how can they say Made in America?
Better not, it probably doesn't have the appropriate IP ratingthis is an amplifier worth drooling all over.
Even the big brother (plain Amplitude8) which is 2 Ohm rated (that one is not) doesn't reach the numbers.Better not, it probably doesn't have the appropriate IP rating
Anyway, should this thing not give a bit more power? 700W in R2 and 1200W in R2 according to datasheet. And this thing goes into protection with 2R? Why?
