D
Deleted member 14468
Guest
Doug, thanks for the thoughtful response. In that vein, then, the Klippel system that Amir uses is doing quite a lot more spatial and frequency measurements to produce the charts and derived information. To your way of thinking, is that data reliable?
I believe so, yes -- at least now. We used the Klippel system back when it was a prototype, since we knew people experimenting with it. It seems greatly improved and will get you around the speaker in ways that are very difficult with traditional measurements in a chamber.
That said, you still have to be able to interpret all that data. Harman has done a bang-up job doing that work -- correlating an encompassing set of measurements with what most listeners prefer.
Still, that doesn't mean that EVERYONE will automatically like it. As our own Brent Butterworth said (he runs a headphone site for us called www.SoundStageSolo.com), everyone should listen to the AKG K371 headphones, which use the Harman target curve, if only to know what the bulk of listeners like. There are always outliers.
Where I think a lot of work needs to be done still, however, is bass-level preference, for speakers and for headphones. This is REALLY tricky still -- and the amount of bass can have an enormous effect on what sounds good and bad. Our reviewer Diego Estan just wrote about this on www.SoundStageAccess.com.
https://www.soundstageaccess.com/index.php/feature-articles/1046-bass-how-much-is-enough
Doug Schneider
SoundStage!
