Hey guys! This is my first post but I have learned a lot from this forum over the past year! I used the REW for dummies thread and eagerly await part 3. Please tell me if the post is in the right place etc.
So, I recently purchased a full set of Auralex ProPanel ProKit for 200 bucks (Link to treatment solution)
on CL and jammed it in my squarish (12x13x8.5) room. The sound improved so dramatically I could not believe it.
I am in a rental and a small bedroom so setup was not exactly ideal. Did not want to put a shitload of holes in the wall so several panels are on the floor. My speaker placement/setup is also terrible but I have no real choice IMO.
The room sounds much more controlled although more bass absorption is definitely needed. I notice the room has deadened significantly and it sounds different to speak in the room vs other places in the house.
I have a measurement mic and tried to quantify the difference. See the link here for waterfall plots and freq. response. I would appreciate any help on fully understanding my room! I don't really understand all of REW. All plots are 1/24 smoothing.
I ran one test with panels in the room and another with all in the hallway.
Gear-
MiniDSP HD DAC
Sansui 9090 - Full recap
A/D/S L1290
Deluxe speaker cables from trashed extension cord
UMIK-1 Calibrated measurement mic
With this room I finally feel that I could upgrade speakers and notice the difference. Looking into powered monitors, Focal Twins, Genelec or ADAM. Also considering DIRAC for EQ if anyone has input? I have not any luck using REW to autogenerate PEQ settings. It sounds grainy?
Is there a link to how to use PEQ responsibly with REW? Especially with no sub.
Gear-
MiniDSP HD DAC
A/D/S L1290
