Transformer Circuit to measure amp, xover, and other +40dBu devices
NathanR
FL, USA
Can someone help me (I'll even pay) design a circuit to measure amps and crossovers and other stuff like that.
I had a LinearX VI-Box that worked great, until I burned it up because of inverting the polarity accidentally.
What I want is to be able to probe anywhere in a circuit and not care about polarity or DC bias or input impedance or whatever.
I want isolation, bandwidth, high input level (50dBu max), low distortion.
I've been reading all the schematics on Jensen-Transformers.com. Good stuff.
I think an H or O pad to bring 50dBu signal down by 20/30/40dBu to +20dBu input into transformer will work well.
Ideally, I want:
8chs total
2- money channels voltage
2- money channels current
2- secondary channels voltage only
2-input power/mains (voltage + current) measurement
Ultimately, I just want to start testing and plotting. I'm tired of trying to learn/teach myself.
For now, just some basic isolation to measure xover would be plenty good IMO.
Context:
Measure this: Danley DNA20K4 (4ch 20kw amplifier)
With this: RME ADI 2/4 Pro SE
LoadBank: hot-water-heater-element bucket(s) 4ch 2/4/8ohm with voltage divider bucket [I'll get photos later]
A oscilloscope can be probing most everywhere as can a trendy Huntron Tracker and differential/balanced input oscilloscope will do even better than the others I posted.
That's true, but it's super annoying to make pretty plots that I can do with APxFlex... or Multitone or Rew or Smaart, or ... any other full-bandwidth testing software.
Well... Sometimes probing with metering gear can cause a ground fault and fry your metering gear. So I would be very careful with using a one-off design.
Yepp
Found that out the hard way :/
That's why I want transformer isolation from now on. Haven't a clue of what circuit is correct.
Are you trying to test an amp under load? Than you would need a large transformer, I dont think Jensen makes those. Why not use a resistive divider? Cheap, accurate, wont saturate, won't add distortion, easily adjustable.
Yep, already have -40dB network, I want isolation.
Don't think thats what you need. Your ADC will still see too high a voltage at its analog in.
USB ISO is to provide extra protection from damage.
I think I'm asking my question incorrectly. Or people aren't reading the post thoroughly. (Likely the former).
Basically, I want to build a better version of this the SP-2SX Speaker to Line-Level DI/Converter.
I have half a mind to just buy that, but I bet we can do better.
Especially with a -40dB pad (need to figure out correct topology). I just need to go +20dBU to +20dBU line-level isolation.
Really what I'm after is just someone to tell me whichever schematic/design they'd choose from Jensen's website.
If you want to save money.
If you want to save effort and time.
Hahaha, those pics are of mine.
I just repaired mine, was pretty easy all things considered.
The Physical Lab boxes are great. Just super expensive.
Hoping to build equivalent units for less than 1/4th
2022 pricing
  • Imp-Box 290,00€
  • ISO-Box 360,00€
  • Filter-Box 495,00€
No, the load is connected directly to the amp output in the normal way. The output transformer is just the first part of a voltage probe.
