classy cheapo
- Joined
- Jun 5, 2022
- Messages
- 21
- Likes
- 17
Let's rekindle the old discussion about high resolution audio formats
I have conducted my own tests which can be considered equivalent to double blinded and I find that I can determine correct file playback 10 times out of 10 between pairs of DSF64/256 and DSF64/FLAC192 files.
Here are the 3 files used in tests shared on Dropbox:
www.dropbox.com
Also, there are 3 more files with md5 extension to be able to verify bit perfect downloads.
Tests were done on Topping DX3PRo+ DAC paired with AKG K612 Pro headphones. Volume on DAC was set to 0 db.
Correct file format output was ensured by checking values displayed on DAC.
More info on the setup here: https://audiosciencereview.com/foru...ne-amp-for-classical-music.34663/post-1221817
Blindness of the test was ensured by loading a playlist consisting of paired files and following steps:
In order to determine whether perceived differences are artifacts of encoding process or the format itself I propose following challenge:
Transcode one of the two given DSF files to any rate FLAC file and/or given FLAC file to any rate DSF file in a way where blind test as described above will not be able to definitely determine correct file playing order.
Why I do not perform transcoding myself?
Because I am not well versed in this black art and default settings not always provide best results. Even more, I am new to the field and do not know any proper audiophile lingo. Only words I can use when describing difference between given files are that one sounds "flatter" or "creamier" than other
What are the prizes?
There are two prizes awarded to first who will submit transcoded file(s) where order of playback cannot be definitely determined. One for DSF -> FLAC and other for FLAC -> DSF transcodings.
Each prize consists of one sponsored download from any of winner's choice high resolution audio sites up to 50 EUR/USD value.
In order to keep this thread civilized and practical please do not post your subjective opinions about audio formats. Stick to questions about setup, testing or links to transcoded files with transcoding parameters.
Please consider participating in this challenge only if you are well versed in audio encoding and you are reasonably sure of your good result.
May the best format win!
Dropbox
- Issuing shuffle command:
mpc shuffle - Playing first file for a first few seconds with redirecting info output to file:
mpc -f %file% play > test.txt - Playing next file for a first few seconds with redirecting info output to the same file:
mpc -f %file% next >> test.txt - Making decision on the order of played files
- Checking the actual order recorded in test.txt file
