love_budget_audio
- Joined
- Apr 13, 2025
- Messages
- 5
- Likes
- 4
Who else is using one of these boards? They can be bought for very little money. Some vendors sell ones with authentic TI chips, I have an XH-M543 from Amazon on a blue PCB which doesn't have a real TI and one from Aliexpress on a red PCB which does have a real TI. They are actually quite good.
The input gain trimpots are seriously terrible quality though and must be replaced. I replaced the 22uF bias capacitor on both of my units with nicer 22uF's. (mostly because i have a large number of 22uF which are too large for most applications).
With a transformer based input or linear PSU then the sound quality is quite good. With a SMPS it is just okay. I found that the sound is still detailed but sounds very harsh and lacks depth (especially in bass frequencies) compared to transformer or linear PSU. I have tried a few different power supplies with mine. What I found interesting is if I use a lower power PSU, it doesn't simply clip at lower volumes like the old Tripath TA2020 based amps. The overall output volume seems lower instead. You can still play it at higher volumes without notable clipping.
I haven't tried replacing any of the SMD caps, or the film caps by the audio outputs. Has anyone tried that? Would be interested to know.
Would be willing to make measurements if there is adequate interest.
