Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
Found on another forum and listened to this track on Spotify. Can't decide if it is a tough "test track" or just a bit unpleasant for the ears (at high volume).
If you have spotify or find it elsewhere, what's your verdict?
It's a reasonable test track (like many 90s and beyond rock songs) because it has very dense harmonic content, in this case basically noise, so it's a good way to check tonality and maybe distortion.
The three repeated bass guitar notes (which also lean to the left side) have some distortion and an unusual boominess (for the initial/applicable section of the track) that doesn't work so well on a full range system (headphones or loudspeakers) for me but otherwise I quite like it. There's plenty of distortion/overdrive via the usual pedal effects on the lead/rythm guitar but that's not unusual. The vocals have a harsh edge too, deliberate or maybe not the best production. Hadn't heard Ossler previously so will likely listen to a bit more.
Not especially dense for me (but I like shoegaze and metalcore so it's all relative).
The three repeated bass guitar notes (which also lean to the left side) have some distortion and an unusual boominess (for the initial/applicable initial section of the track) that doesn't work so well on a full range system (headphones or loudspeakers) for me but otherwise I quite like it. There's plenty of distortion/overdrive via the usual pedal effects on the lead/rythm guitar but that's not unusual. Hadn't heard Ossler previously so will likely listen to a bit more.
