Totem Acoustics Rainmaker Speaker Review
Rate this speaker:
    Votes: 151 68.0%
    Votes: 66 29.7%
    Votes: 5 2.3%
    Votes: 0 0.0%
This is a review, listening tests and detailed measurements of Totem Acoustics Rainmaker Speaker. It is on kind loan from a member. It was released back in early 2000s for around $1,000 (pair):
The look and feel of the speaker lands in "good" category with nice use of wood/veneers which you don't see often today in small/budget speakers. As you may be able to guess, this is a rather small speaker which brings challenges usually in the form of dynamics. Not much to see on the back:
If you are not familiar with Totem Acoustics, the brand is the darling of Custom Integration channel. Company founder and designer, Vince Bruzzese, is at seemingly every show, putting on great demonstrations. Website and show booths are covered with pictures of models which I am sure helps with the male dominated industry they target. Recent claim to fame has been crossoverless woofers but I think this one does have one.
Even though this speaker is long discontinued, I wanted to get some coverage of the brand and hence this review.
Testing was performed without a grill and with tweeter as the reference axis.
Totem Rainmaker Measurements
As usual, we start with our usual frequency response ("spin") measurements:
Ouch! I must say I was not ready to see such uneven response replete with resonances in the upper midrange and lower treble. Near-field response shows the source being cabinet and woofer break up:
This is probably the worst example of such abnormal responses I have seen.
We can see other signs in both impedance/phase response and CSD/Waterfall:
Early window ironically is a bit better due to narrowing of the high frequency response (see directivity later):
The sum is not pretty as far as predicted in-room response:
Totem Rainmaker Speaker Predicted in-room Frequency Response Measurements.png
Lack of a waveguide means wide directivity starting around crossover but then narrowing at the upper treble:
The wider directivity in lower frequencies should give a more diffused soundstage and narrow up above as noted, help with the brightness.
Distortion is low at 86 dB SPL:
At 96 dBSPL I could hear strange noises but the woofer did not thankfully bottom out.
Finally, here is the step response:
Totem Rainmaker Speaker Listening Tests
The out of box experience was not as bad as the insult on the eye that the frequency response was. Continue to listen though and the boomy low end starts to annoy while the boosted upper treble takes out hiss from tracks you didn't think had any! In an odd way though, it balances things a bit giving you a feeling of brilliance that the lower treble had taken out.
I build my EQ filters by eye and while the method usually works, it is no match to the extremely uneven response of the Rainmaker. I tried anyway:
In most tracks, this was an improvement but in a few, I thought the stock tuning was maybe better. At shows, Vince plays techno/modern music so I tried that with and without EQ. For sure, the failures of the speaker were less evident in that kind of content (think Deadmau5).
Objectively there are many failures in the design of Totem Rainmaker. Resonances are a problem as is very uneven frequency response. Subjective experience is not that bad, aided by decent dynamic range and ability of the speaker to keep going instead of falling apart as some small speakers do. Mind you, it is still "bad" but just not as much of an assault on your ears as the measurements are on your eyes.
I can't recommend the Totem Acoustics Rainmaker.
  • Totem Rainmaker Frequency Response.zip
bogart
Thanks for adding this brand to the set of speakers reviewed. I had (then sold) a pair of their Sttaf towers. While they were initially pleasant sounding I was happy to sell them to move into Revel speakers.
Totem definitely comes off as under-engineered here.
SuicideSquid
Hey it's my Rainmaker!
I used to sell these in the 2005-2010 window and they were a speaker that "showed" very well for its budget. You can definitely see why looking at the response. Lots of midbass, lots of treble, made them stand out when demoing next to other similar-budget speakers. I used a pair for awhile as my mains but found them a bit bright and fatiguing to listen to so they were relegated to my rear surrounds and replaced with Totem Forests up front (which measure much better and have a much more neutral sound).
Thanks for testing them Amir! Very cool to see.
H-RYCAJ
Saw this one coming.
Edit: 1000$ says the advert for this speaker had a pretty lady or two.
McFly
NZ
Rainmaker because you be crying after searing holes in your eardrums.
bogart
Ha! In fairness, I wouldn’t quite put these in the searing-your-eardrums category. There are much worse offenders to the ear, though these charts definitely offend the eye.
SuicideSquid
They are absolutely reasonable to listen to. You will notice a bit of a bump in the treble and midbass but it only becomes objectionable at high volumes or during long listening sessions.
USER
Great review, Amir! Glad to see a speaker that is still seemingly always around--most often for sale used at an audio purveyor. This type of review helps understand the overall landscape. I always enjoy them. Totem is one of those brands that even subjective reviewers started second guessing after a while. Good to know why!
Timmeon
New York
I feared this day would come! I still love my Totem Hawks which I'm almost certain would show similarly disappointing measured results. I don't actually find them fatiguing at all, but I only ever listen at low to moderate volume. They are entertaining at any listening position.
Oh well. For what it's worth, the compact minimalist look appeals to me (though I did plasti-dip the chrome "claws" which were a bit gaudy for my taste). They'll stay.
I do appreciate the data. Another excellent review.
Steve Dallas
A Whole Other Country
Wow. Totem does Batman response even better than B&W!
Maiky76
French, living in China
Hi,
Here is my take on the EQ.
Please report your findings, positive or negative!
The following EQs are “anechoic” EQs to get the speaker right before room integration. If you able to implement these EQs you must add EQ at LF for room integration, that is usually not optional… see hints there: https://www.audiosciencereview.com/...helf-speaker-review.11144/page-26#post-800725
The raw data with corrected ER and PIR:
Score no EQ: 2.9
With Sub: 4.9
Spinorama with no EQ:
  • Too many resonances
  • Poor Directivity
  • Far from neutral balance
Directivity:
Better stay at tweeter height
Horizontally, better toe-in the speakers by 10/20deg and have the axis crossing in front of the listening location, might help dosing the upper range.
EQ design:
I have generated two EQs. The APO config files are attached.
  • The first one, labelled, LW is targeted at making the LW flat
  • The second, labelled Score, starts with the first one and adds the score as an optimization variable.
  • The EQs are designed in the context of regular stereo use i.e. domestic environment, no warranty is provided for a near field use in a studio environment although the LW might be better suited for this purpose.
  • Too many resonances to EQ them out and might not translate on other units...
Score EQ LW: 5.6
with sub: 7.5
Score EQ Score: 6.1
with sub: 8.0
Code:
Totem Rainmaker APO EQ LW 96000Hz
January122023-104534
Preamp: -3.7 dB
Filter 1: ON HPQ Fc 48.85,    0.00,    1.50
Filter 2: ON PK Fc 177.55,    -3.49,    1.11
Filter 3: ON PK Fc 900.91,    -3.81,    6.42
Filter 4: ON PK Fc 867.85,    2.91,    1.13
Filter 5: ON PK Fc 2940.39,    2.28,    4.22
Filter 6: ON PK Fc 6735.47,    -3.33,    1.34
Filter 7: ON PK Fc 10362.93,    -2.19,    2.85
Totem Rainmaker APO EQ Score 96000Hz
Preamp: -3.7 dB
Filter 1: ON PK HPQ 48.85,    0.00,    1.50
Filter 2: ON PK Fc 170.55,    -3.69,    1.11
Filter 3: ON PK Fc 879.46,    -5.54,    5.76
Filter 4: ON PK Fc 835.54,    4.01,    1.86
Filter 5: ON PK Fc 2947.39,    2.74,    4.39
Filter 6: ON PK Fc 3739.39,    -1.57,    1.22
Filter 7: ON PK Fc 6508.42,    -4.27,    1.48
Filter 8: ON PK Fc 10590.03,    -3.18,    1.92
Spinorama EQ LW
Spinorama EQ Score
Zoom PIR-LW-ON
Regression - Tonal
Radar no EQ vs EQ score
Nice improvements but still a lot of resonances...
The rest of the plots is attached.
Bonus: Amirm EQ
Score EQ LW: 4.1
with sub: 6.1
  • Totem Rainmaker APO EQ Score 96000Hz.txt
  • Totem Rainmaker APO EQ LW 96000Hz.txt
AndreaT
Commonwealth of Massachusetts
A Totem bookshelf speaker failed to please my ears when I listened to them at a High End dealership outside Boston, early 2000’s. I had, at the time, a pair of ProAc Studio 100, and the Totems did indeed sound bright and splashy. As a comparison, I moved to another demo room and fell in love immediately with a pair of Revel Ultima Gem: absolutely delightful but out of my price range back then.
Thank you Amir for a wonderful review and thoughtful listening impressions!
norman bates
Iowa, US
I wonder if adding a bunch of acousta-stuf would help the 800-3khz region ?????
Those box resonances are probably sneaking out the port.
The climb past 3khz might not be so bad sitting 10'away, especially to those who boost the hf.
Lastly, rolling off at 150hz, well, it's a 5.5" woofer.
A subwoofer that goes that smoothly higher than that is mandatory
"As always from Totem, the Rainmaker's measured performance reveals some excellent speaker engineering. However, I would have preferred not to have seen those cabinet resonances in the upper midrange.—John Atkinson"
SuicideSquid
Just from subjective experience, from a fair bit of time listening to and comparing the Rainmaker, Hawk, and Forest, the Hawk would definitely measure a LOT better than the Rainmaker. It's got a similar midbass hump but much smoother through the mids and with a bit of a treble bump, but probably closer to 2-3dB rather than the 5-6dB Amir measured on the Rainmakers.
Based on my ears and on some measurements done by Stereophile and others, the Forests are about as ruler-flat as a floorstanding speaker gets between around 60Hz and 10kHz.
lateralous
You're in an enviable position, then ;)
You enjoy what you have, so no problems there. Then you have an entire world of speakers that excel "technically" to explore, should you choose (maybe you have, and simply like the Totem best; again, no problem).
Timmeon
New York
Ah, interesting. Prior to the Hawks, I had the Arros which I might have liked a tiny bit more. As far as I could tell the Arros had slightly smoother treble. I was second-guessing myself the few times I swapped them to compare. The Arro just couldn't compete in the low frequencies for obvious reasons, but I enjoyed the hell out of those little things.
Appreciate your thoughts and lending your speakers to be measured!
