openbaffle3278
- Joined
- May 5, 2018
- Messages
- 88
- Likes
- 53
Interested in some opinions here. My Digital audio source is currently my old style tower MacPro, which lives to the side of my main speakers. Currently running a 20' optical cable out of the MacPro to a Cambridge DacMagic Plus, which is between my speakers and close to my amp. Using the balanced outputs of the Cambridge to drive my mains and the RCA outs to power separate sub amps.
Running a 15' USB cable seems impractical/prone to problems, but I wondered if adding a Topping D10 right by my computer and going USB -> S/PDIF and then running a 15' S/PDIF cable would be a better option than the optical route directly out of the Mac.
I use Swinsian to playback lossless files on my computer (all 44.1kHz/16-bit CD rips) and also stream from Spotify.
Eventually, I'd like to upgrade the computer and get something quieter, like a 27" retina iMac. At that point I will have to use the USB -> S/PDIF convertor.
Another (less interesting to me) option is to move the DAC by the computer and run 15' XLR cables and 15' RCA cables out of the DAC and into my stereo sub amps and main amp. But I think that introduced unnecessary complexity, possibility to pick up noise (at least in the RCAs) and adds a fair bit of cable cost.
So I guess questions are:
1. Would running a 15' USB cable directly to the Cambridge be worse than the optical out of the MacPro (Has this been investigated in terms of degradation of the audio stream/introduction of distortion artifacts)?
2. Would getting a Topping D10 to act as a USB -> S/PDIF convertor and then running a 15' S/PDIF cable be the better option?
3. Am I overthinking this and should just be happy with the optical out, and save the Topping D10 cost towards my DAC upgrade?
My plan in the near future is to likely upgrade the Cambridge DacMagic Plus to an RME ADI-2 DAC largely based on the fact that I am looking for something that has remote volume control and due to its exemplary measurements presented on this forum. But certainly the Topping DX7S (since it appears that you can use a remote with this, albeit not included), Benchmark DAC2 HGC and Aune S6 are in the running as alternatives. My two main DAC requirements are:
1. Balanced and unbalanced outs that run simultaneously and can be attenuated from the DAC (no pre required in the system).
2. Remote volume and source selection control.
ETA I found this: http://archimago.blogspot.ca/2013/04/measurements-usb-cables-for-dacs.html, which would seem to indicate no measurable signal degradation with up to a 17' USB cable.
